Page 5 of 6 1 2 3 4 5 6
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: BobShaw] #598333 05/04/05 12:15 AM
Kevin C Offline
That is the standard converter stall test. My turbo does the same thing but you can get an idea of the stall speed.
What counts is to understand that stall speed is the RPM the motor climbs to under those conditions and is typicly above 1200 rpm.
Also try using the E brake as well as the service brake to get a bit more rear braking. I have also upgraded my rear wheel cylinders to get a bit more rear brakes. It give a bit better match to the V6 brakes in the front.
Kevin
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: sparkem] #598334 05/04/05 03:48 PM
Speaking of adapters: I designed a set of three components to mate a 4.3 to the stock KM-148 Mitsi tranny. I drew them on a CAD system and had an engineer here at work cut them on a CNC. They were beautiful, and the amazing part was that it worked. I used a 1" plate at the back of the GM block, a crankshaft extension, two flexplates (one to crank the engine and the stock plate to hook up to the torque converter) and a 1/2" plate to connect the trannsy to the GM plate. As I said, it worked , but it was not totally reliable as I blew the front trans pump seal a couple of times. I finally caved and just put in the 700R and a modified NP207. I kept pics if you wanna see 'em. Just give me an e-mail address.
Re: 4.3 V6 Raider/Montero/Pajero club? #598335 05/04/05 03:56 PM
Chris_J Offline
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: Chris_J] #598336 05/04/05 04:26 PM
sparkem Offline
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: BobShaw] #598337 05/04/05 06:21 PM
but is a a mitsu if its got a GM engine? i think the swappers may have to do some soul searching...
Nah, it's still a Mitsu, just a highly customized one. There are a lot of cars with other makes of engines in them from the factory.
With that line of thinking, the Dodge Caravan's with the Mitsu engines in them would be tough to call Dodges...
Re: 4.3 V6 Raider/Montero/Pajero club? #598338 05/08/05 02:55 PM
BobShaw Offline OP
Mudflap
What is your email address?
Bob Shaw
superchief87@adelphia.net
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: sparkem] #598339 05/08/05 02:59 PM
BobShaw Offline OP
Sparkem,
Is your Toyota with the Chevy engine a CHEVota or a
TOYlet? <img src="/forums/images/graemlins/lol.gif" alt="" />
My RAIder with a blaZER drive train is a RAIZER
"the cutting edge of technology" <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Bob Shaw
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: BobShaw] #598340 05/14/05 12:34 AM
BobShaw Offline OP
At first, in my Raider, I Dodge'd it.
That was not adaquate so:
I Ram'ed it.
That did not work either so now:
I Chev'd it. <img src="/forums/images/graemlins/lol.gif" alt="" />
Bob Shaw
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: BobShaw] #598341 05/14/05 08:40 PM
8
85monteroS Offline
Dont forget me bob i know i dont post much any more but i am still wheelin it needs a speedy sleeve on the crank but thats gravy!!!
85 monty swb,full 4.3swap,5spman&hd231tcase,34"swampers,dualbouncy, softop done,new tbars,S10 rear spring w/dual shackles.
Re: 4.3 V6 Raider/Montero/Pajero club? [Re: 85monteroS] #598342 05/14/05 09:12 PM
LandRaider Offline
pics pics pics!!!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6416 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-06-06 21:51:06 UTC
