first head job, what to do? #598713 05/01/05 05:05 PM
Movinfr8 Offline OP
Ok, since I have your attention, I have the head off the 90 Jetta I recently bought, and I can see why head gaskets could be an issue! not much room between holes. Since I have the head off, what do I do? Was planning to take it to a machine shop to be checked for warpage, and cracks, what else should be done while it is out?
TIA,
Norm
87 raider 2.6
5-speed manual
Re: first head job, what to do? [Re: Movinfr8] #598714 05/01/05 10:58 PM
check the head to be straigth, replace valve inner rubbers (these two will be done by a shop), replace intake manifold, exhaust manifold, head cover and head gaskets. Also, replace timing belt and tensioner, camshaft and crankshaft seals. Rotor, rotor cap and spark wires along with the sprk plugs also a BIG plus. after this you shouldn't have to in there again in a big while. Had one myslef a while a go (89 GLI, 2000, 16V, DOCH) great machine. I have factory service manuals and a bunch of information. Let me know what you need and I'll try to help.
good luck <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mike
Re: first head job, what to do? [Re: Movinfr8] #598715 05/02/05 03:04 AM
Quinnchuck Offline
Toubleshoot the prob "How many miles, could it be the cause of over heating that the head gasket blew"?,RAD,WATER PUMP,???WHY DID THE HEAD GASKET LET GO??? Pressure test rad, replace pump & main hoses /w thrmostat.Let us know what you've dun & miles?BUDWEISER & JUDAS PREIST! It's so refreshing!!
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
"YOU CAN ONLY LEARN SO MUCH KNOWLEDGE IN A LIFETIME..BUT IMAGINATION IS WHAT MAKES THE WORLD GO AROUND"
89 POWER RAM D50 4X4 XCab 2.6L
91 Grand Prix GTP 3.4L
87 Jeep YJ Laredo 4.0L EFI
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5913 MB (Peak: 0.6453 MB) Data Comp: Off Server Time: 2026-07-17 02:25:00 UTC
