replace engine? or headgasket? #599014 05/02/05 05:49 PM
im thinking about picking up a 93 toyota 4runner for 250, it needs suspension work which is no problem. it also has a blown headgasket, i looked up some pricing on new engines i can get one for aroun 2k...just wondering if it would be more worth it to just put in a new headgasket? or replace the whole engine? and how big of a job would it be?
Re: replace engine? or headgasket? #599015 05/02/05 10:15 PM
4
4mudder Offline
what engine is it
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: replace engine? or headgasket? #599016 05/03/05 12:46 PM
ChrisH Offline
Buddy of mine had Toyota replace his 22re headgasket for around 1200 bucks. If you're up to doing it yourself, it'll cost you about $50 dollars and some free time over the weekend to get a full gasket set in from engnbldr.com
It's well worth checking your block for warpage and getting your head shaved at a machine shop which'll cost some extra $$ but much less than 2k. <img src="/forums/images/graemlins/wink.gif" alt="" />
Although I've heard from ppl that if your block is warped it may be easier to leave the head as is and try to either shim it or just replace the HG.
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: replace engine? or headgasket? #599017 05/08/05 02:34 PM
How bad is the blown gasket?
I had a 92 Ford Tbird, really nice car, ran great, handled beautiful, I really liked the car, but it had a bad gasket, always having to fill up the water, couldnt drive far without it overheating.
Some guy told me about sodium silicate, I tried it, the car quit surging on idle, never had to add water, it ran beautiful and passed smog ever since.
Re: replace engine? or headgasket? #599018 05/10/05 05:25 AM
CORunner93 Offline
If I had only paid $250 for the whole truck, I'd be thinking I had the money for a 3.4L or V8 swap.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: replace engine? or headgasket? #599019 05/10/05 07:50 PM
F
fox74 Offline
Replacing headgasket is not real a hard job, but sometimes the head is cracked then you need to get a remanufactured head around $500. What I would do is to remove the head and take it to a machine shop to find out what condition it is in, and go from there. Some guy mentioned the block may be warpped but this is new to me, never heard of it happening. It should cost you around $100 to get head resurface and valve reseated, not a bad deal. Also doing a compression test before doing anything is not a bad idea because it will tell you a lot about condition of the engine, normally you should get very close readings on all cylinders except the one with blown gasket. I always consider what is the market value of the car in great condition and never go over that trying to fix a J.....
1997 Toyota 4Runner SR5
Re: replace engine? or headgasket? [Re: fox74] #599020 05/12/05 12:09 AM
If you do need a head like I did, EB sells some awesome NEW heads. I ordered one complete with valves, springs and all, already assembled, his headgasket rocks! Total for new head with valves and all, HG set and headbolt set was around 470 bucks. All new stuff. I installed it this weekend, and it runs 100 times better than before the head failed.
Re: replace engine? or headgasket? #599021 05/12/05 04:46 PM
F
fox74 Offline
Do you have a Website for EB. Thanks
Re: replace engine? or headgasket? [Re: fox74] #599022 05/12/05 08:40 PM
Ganoid Offline
EB's Toyota section
I bought all my 3.0 rebuild parts from EB and I could not be happier.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6191 MB (Peak: 0.7201 MB) Data Comp: Off Server Time: 2026-06-23 13:08:55 UTC
