Page 1 of 3 1 2 3
To R-134 or not to R-134 #599044 05/02/05 08:03 PM
Houston Offline OP
OK, I'm into the A/C to replace my leaking Evaporator, and the related parts with the job[drier, etc] Here's my question, has anyone done a R-134 conversion to a high mileage Gen 2 Montero from the stock R-12 freon? Did you run with this conversion long enough[like several seasons]to see how it performs when compared to the cooling of the R-12? Any downside like shortened compressor life due to the high pressures that R-134 normally has on the high side of the A/C system? Thanks for any info you can shed. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: To R-134 or not to R-134 [Re: Houston] #599045 05/02/05 08:43 PM
I've not done the conversion on a Monty, but I have done it on many road tractors. A system converted to R-134 does not cool as well as the R-12, but the difference is negligible. And in the Monty you won't notice it much. Also, before everyone gets up in arms, the systems that are R-134 from the factory cool just as well as R-12. The conversions are the only time I ever encountered a difference. As far as reliablity you should not run into any problems. And of course the biggest factor is the cost and ease of getting the 134. The only way you can get the 12 is take it to a shop or be certified on A/C and then it is more expensive. I hope this helps.
Re: To R-134 or not to R-134 #599046 05/02/05 08:54 PM
Houston Offline OP
Thanks, I too have done R-134 conversions and have worked on A/C systems since the late '80s. Along with using Ester Oil as your conversion oil for the system, the usual suspects are a slight drop or lack of cooling out of the condensor if it's sized or tubed for R-12 when you convert the system over to R-134. Evaps, valves, lines are usually not an issue. O-rings can always be changed over to R-134 material if needed. So, my usual biggest concern is whether the compressor can handle the higher pressures that R-134 puts on the system, and if there's shortened service life from that since compressors aren't usually cheap, even with a rebuilt.
Getting R-12 isn't an issue either, aside from gulping at whatever the wholesalers are charging for a 30 lb can each year <img src="/forums/images/graemlins/smile.gif" alt="" /> Yeah, R-134 at Pep Boys retail, or from your jobber in a 30 pounder is much cheaper, so I'd like to go with that if possible. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: To R-134 or not to R-134 [Re: Houston] #599047 05/02/05 11:54 PM
motero Offline
Houstan
I have ran R134 for the past five summers. It works great in my 89. I did not have any leaks and still don't. No problems with the compressor yet.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: To R-134 or not to R-134 [Re: motero] #599048 05/03/05 06:41 AM
RoryTek Offline
Has anyone tried these?
Maxi-Frig
Freeze 12
Rory N6OIL
88'Monty 2.6l 2dr,5spd,Silver,2 bouncy seats,LSD
Most Wanted Synthetics
Re: To R-134 or not to R-134 [Re: RoryTek] #599049 05/03/05 12:56 PM
1987Raider Offline
Did the conversion on my BMW 325i a few years ago -- kept it for a couple of years after doing it (wife wanted a 4x4 so the BMW had to go) -- anyway, no issues, no problems, couldn't tell the 134 cooled any less than the 12.
Terry
1987 Raider 2.6L Auto -- rebuilt, by hand, by me -- Bouncy Seat/LSD/Aisin Hubs -- CB/Whip Antenna --Jensen Stereo -- Fire extinguisher .
Re: To R-134 or not to R-134 [Re: RoryTek] #599050 05/03/05 01:06 PM
conner Offline
Maxi-Frig
Freeze 12
I converted my SWB over last year. I did replace all the "O" rings and flushed it before changing over. I installed ester oil and 1.7 lbs of R134,(MAC recommends 85% of R12 capacity). It worked great last year with no problems, There was very little increase in pressures and it cooled that SWB very well.
The feedback that i am getting on all the other alternative refrigerents is not good.I know thats a broad statement but it was from what i consider reliable sources. However try it. If it works, let us know.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: To R-134 or not to R-134 [Re: conner] #599051 05/03/05 01:51 PM
Chris_J Offline
STAY AWAY FROM FREEZE 12 IT HAS KEROSENE OR SOME SORT OF GASOLINE IN IT. DO NOT USE IT. <img src="/forums/images/graemlins/scared.gif" alt="" /> or at least thats what I learned in my 3 years in selling parts.
Re: To R-134 or not to R-134 [Re: Chris_J] #599052 05/03/05 02:01 PM
W
wyleone Offline
Thats not Freeze 12 you are thinking of, Freeze 12 is made up of 85% 134a w/ a heavier gas to push the mineral oil in the system. But that is true, there was a big scare back in the mid 90's, jack leg refrigerant mfrs were using propane and a type of butane? (I think) It cools well but when you get in a wreck or have a leak in the engine compt <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: To R-134 or not to R-134 [Re: wyleone] #599053 05/03/05 02:39 PM
Houston Offline OP
Thanks to everyone who posted in response to my questions.
The deal is done, I installed the Evaporator, expansion valve and new rec-drier at work last night, and stuck with R-12 for now. If anyone wants a 'blow by blow' posting on how to R&R the evap in a Gen 2, along with part numbers and O-ring and hardware listings, let me know and I'll write up a service/job description for the board. I used no air tools, took my time, and put the system under a vacuum for 25 minutes since it had been leaking for so long and was now also open to outside air with the repair work. Total time was 2 1/2 hours, start to finish. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6425 MB (Peak: 0.7677 MB) Data Comp: Off Server Time: 2026-05-29 15:17:34 UTC
