Fuel Pressure??? #599166 05/03/05 02:20 AM
Daniel_T Offline OP
Just wanted to know what the fuel pressuer was on the 2.8 Trooper fuel pump. I need to get my pressure up to like 65 for the vortec 4.3 Can I just leave the one in my tank and add an in line fuel pump to get the pressure that I need?
Thanks,
Daniel
"Thanks for the joy that you gave to me"
Re: Fuel Pressure??? [Re: Daniel_T] #599167 05/03/05 03:17 AM
E
EricW Offline
The fuel pressure for the 2.8L is only 9-13psi. I was thinking that maybe you could use a larger Isuzu pump, but the 3.2 was only rated at 41-46psi and the 3.5 was only 42-45.
That cpi engine that you are using has to have that 65psi
to even cycle the injector"spider" assembly.
I would just run an external pump with a regulator, it will draw the fuel through the old pump.
HTH
1996 Trooper S 3.2 5sp OME919/ProComp ES9000
BFG Dueler A/T REVO 265/75R16 w/Snowflakes
1991 Trooper 2.6 5sp 33x12.5 BFG T/A
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5879 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-05-26 03:44:25 UTC
