Air bag question #600322 05/06/05 01:33 AM
F
fox74 Offline OP
I am installing an anti-theft alarm in my car, I am worried about the airbag being active while I am messing around with the wiring, what is the best way to deactive the airbag, is it safe to pull the airbag fuse. Thanks in advance
1997 Toyota 4Runner SR5
Re: Air bag question [Re: fox74] #600323 05/06/05 01:51 AM
Dandeman Offline
Toyota Moderator
Per Toyota documentation...
Disconnect the battery and wait a minimum of 90 seconds before doing your work. The reason for the 90 second delay that the airbag system has its own electrical energy storage and it takes that long to drain down.
Also the airbag wiring is covered with a yellow loom so it can be easily identified so you'll know not to tamper with it..
Re: Air bag question [Re: Dandeman] #600324 05/06/05 02:03 AM
F
fox74 Offline OP
Thanks for the reply, but I wish there was a way that I had power to the other systems to test the installation. Removing the battery kills everything.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-20 16:44:58 UTC
