supra LSD in front axle?
#600717
05/06/05 10:25 PM
I just removed my ARB from the front axle. Had to cause I swapped it for a 2JZ engine and I seldom use the ARB. I wanted to retrofit the OEM open carrier (Landcruiser 70-80 series high pinion) but discoverd that I have 3 allmost identical carriers in my shed. I recall stripping 2 supra's, an '86 7M-GE auto (with optional LSD package) and a '92 7M-GTE manual. Plus I have the LC open carrier from the high pinion. I can identify one set as from a supra cause it had the 3.7 gears. This is also the LSD which is 5mm smaller than the other 2 LSD's. Dunno if its from the turbo or not. So I'm left with 2 identical carriers with identical dimensions and bearings. They are so identical that I cannot see which one is the LSD and which one is the open model. I have to open one up or use 2 shafts to find out which is the lSD. Since they are the same I have a choise. LSD or not?
Now back to my question: is it worth to have an LSD up front? Anybody use a supra LSD up front before?
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle LC80 rear axle, coils and locker 4.88 gears 2JZ-GE+turbo+intercooler
Re: supra LSD in front axle?
[Re: 4runner4ever]
#600718
05/06/05 10:53 PM
FWIW, I just installed one a few weeks ago (Supra LSD's front and rear) but haven't had the opportunity to take the truck off-road since the install. But the Supra LSD in the rear is killer -- very happy w/it -- and I'm looking forward to seeing what the front LSD does for traction, as I previously had open diffs at each end.
The 8" clutch-type Supra LSD is identified by the almost-visible clutch discs, which can be partially seen through the holes at either end of the carrier.
-Jeff
[Re: mosk]
#600719
05/07/05 12:56 AM
#600720
05/07/05 08:48 AM
Okay, I will give it a try. Those allmost visible clutchplates are indeed the only thing that is different between the 3 units. (and the side bearings) Two of them show plates with square lines on them and 1 unit does not have those square lines. So I guess this is the open unit.
Black '90 4R
[Re: 4runner4ever]
#600721
05/07/05 06:50 PM
Okay, I will give it a try. Those allmost visible clutchplates are indeed the only thing that is different between the 3 units. (and the side bearings) Two of them show plates with square lines on them and 1 unit does not have those square lines. So I guess this is the open unit. Bingo!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6066 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-11-16 08:41:29 UTCValid HTML 5 and Valid CSS
