1988 Trooper - I think I need shocks - What kind? #600963 05/07/05 09:30 PM
8
88_Super_Trooper Offline OP
Over the last couple of months I have noticed that the front end and steering wheel will periodically shimmy/bounce at freeway speeds (55-65 mph). I had it aligned six or eight months ago and they said all the steering/suspension components looked/felt good. I am assuming it is in need of shocks since it has been many years since they were replaced.
I use it mostly on the street with occasional logging road/off highway use. I do use it to haul some moderate loads sometimes as well as towing moderate loads (2600lbs).
What would be a good shock to go with for these conditions? Since I got the 2001 Trooper the towing duties of this one should be reduced but it will still be used to haul stuff (yard stuff, auto stuff, home maintenance stuff, etc.) I like a moderately firm ride. Not too soft. It is still a truck after all! Any suggestions?
You wouldn?t worry what people thought about you if you realized how little they did!
1988 Isuzu Trooper Limited, Bone Stock, 2.6L, 5 speed manual trany.
2001 Isuzu Trooper Limited, Bone Stock, 3.5L, Automatic.
Re: 1988 Trooper - I think I need shocks - What kind? [Re: 88_Super_Trooper] #600964 05/07/05 10:02 PM
N
NotSoSimple Offline
I have ProComps (See Sig) and I love 'em. Prrice was right also because I was on a budget at the time.
They do have an upgrade for when you will be towing loads, but I dont see the need for those in your setup.
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: 1988 Trooper - I think I need shocks - What kind? [Re: NotSoSimple] #600965 05/07/05 11:04 PM
carsonmnc Offline
You can find the ProComps for a great price too, they also have many options for boot colors <img src="/forums/images/graemlins/wink.gif" alt="" /> I am buying mine from jackit.com along with shackles and bushings..
~Carsonmnc
Re: 1988 Trooper - I think I need shocks - What kind? [Re: NotSoSimple] #600966 05/07/05 11:29 PM
8
I will check out the ProComps. I see many people seem to like the Rancho, OME and Calmini shocks as well. Would these be overkill? I don't want to get crazy expensive, but I do want them to last. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 1988 Trooper - I think I need shocks - What kind? [Re: 88_Super_Trooper] #600967 05/08/05 05:17 AM
litnin Offline
I've got Gabriel's on my '89 and they are great.
I think I paid $20/each for them at PepBoys and they have a lifetime warranty. Been mudding with them a couple of times and they did fine.
They ride great on the road also.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: 1988 Trooper - I think I need shocks - What kind? [Re: 88_Super_Trooper] #600968 05/08/05 08:15 PM
pucci Offline
I have ProComp ES9000's, some people say they are too stiff but I think they are just peachy. if you keep your eyes open, 4WP frequently runs a 'buy 3 get 1 free' promo, plus free shipping. I forgot what the total was for my set, but it was a great deal.
2.6 Trooper
2.0 Impulse Turbo
Re: 1988 Trooper - I think I need shocks - What kind? [Re: pucci] #600969 05/09/05 02:19 PM
HCMP Offline
I bought procomp ES3000's because they were cheap. I call them stiff in combination with coils that you don't have in the back of an amigo which you don't have. The bushings blew out on both of them in less than 2 years with average on road miles and a decent amount of off road time.
Just put on Bilsteins and they feel pretty good to start. No doubt they are more pricey How they hold up, we'll see.
YMMV
--jeremy
Re: 1988 Trooper - I think I need shocks - What kind? [Re: 88_Super_Trooper] #600970 05/09/05 03:30 PM
dvtrooper Offline
KYB makes a great shock and also on the cheap side, i've had on my 88 trooper for 15 years in the rear and had on the front up until i did my sas 4 years ago. Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: 1988 Trooper - I think I need shocks - What kind? [Re: 88_Super_Trooper] #600971 05/11/05 02:23 AM
maxwell417 Offline
If not the shocks, check the upper control arm bushings. I had to replace mine.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 1988 Trooper - I think I need shocks - What kind? [Re: maxwell417] #600972 12/26/05 02:54 AM
trooper_91 Offline
maxwell417
What shocks do you run on your Trooper? Have you done the leaf over axle flip? Thanks for the link to your pictures I enjoyed them. <img src="/forums/images/graemlins/patriot.gif" alt="" />
What, Where, how did I get here again?
Hey guys....how do I get it in 4 wheel drive?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6388 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-06-21 09:58:16 UTC
