Error codes & spark plugs for 2000 Trooper #602250 05/11/05 01:45 PM
fourwd1 Offline OP
Is there a way to get them w/o an OBD II reader ? Like when you cycle the ignition switch and count the check-engine-light flashes on some vehicles ?
Reason I ask is yesterday it suddenly started running rough. You could hear and feel it. I'm thinking a fouled plug or something. I'd like to be able to get an error code to be sure I'm on the right track.
The check engine light has not come on.
Also, is there a trick to replacing plugs on the 3.5L ?
I pulled one (it looks OK).
The coil comes off easy enough but getting the rubber spacer out was a pain, and I'm thinking getting it back and with a good connection on the plug, is going to be worse.
Any hints ?
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Error codes & spark plugs for 2000 Trooper [Re: fourwd1] #602251 05/11/05 03:21 PM
BigSwede Offline
Getting the coils off is the hard part, sometimes the rubber sticks to the plugs, especially if they haven't been changed in a long time. Putting the coils back on is easy, they should snap on to the plug with no problems.
The only hint you need is for the rear drivers side plug, the brake system prevents getting a socket and long extension in there. All you have to do is feed in 2 short extensions one at a time.
Plugs on a Trooper are about as easy as it gets otherwise, half-hour job.
Serenity now!
Re: Error codes & spark plugs for 2000 Trooper [Re: BigSwede] #602252 05/11/05 04:35 PM
fourwd1 Offline OP
Thanks. The one coil I pulled off so far was no problem, I was mainly concerned about reinstalling the rubber sleeve and getting it to mate properly to the spark plug contact.
Is there any way to get codes w/o a scanner?
Re: Error codes & spark plugs for 2000 Trooper [Re: fourwd1] #602253 05/11/05 06:00 PM
BigSwede Offline
Sorry, not on OBD II vehicle...wish there was.
Serenity now!
Re: Error codes & spark plugs for 2000 Trooper [Re: fourwd1] #602254 05/11/05 09:19 PM
ProBMXer1313 Offline
If your check engine light isn't on then there are no codes to pull. I don't believe there is any way to pull codes w/o a scanner. AutoZone will let you barrow there scanner or pull the codes for you for free.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: Error codes & spark plugs for 2000 Trooper [Re: ProBMXer1313] #602255 05/12/05 01:34 PM
fourwd1 Offline OP
Well I replaced all the plugs last night with no difficulties. One was bad, which would account for it running rough.
Started it up this morning and tons of white exhaust is pouring out.
Now what is going on ?
Re: Error codes & spark plugs for 2000 Trooper [Re: fourwd1] #602256 05/12/05 02:31 PM
BigSwede Offline
One possible explanation is a bad head gasket...check your coolant for level and/or bubbles, and your oil for coolant.
Serenity now!
Re: Error codes & spark plugs for 2000 Trooper [Re: BigSwede] #602257 05/12/05 04:20 PM
fourwd1 Offline OP
Yeah, I was hoping that wouldn't be the answer <img src="/forums/images/graemlins/angry.gif" alt="" />
Of course it's probably out of warranty <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6265 MB (Peak: 0.7239 MB) Data Comp: Off Server Time: 2026-05-29 14:37:46 UTC
