T-Case #604170 05/17/05 05:37 PM
Roberts89trooper Offline OP
Dose Anybody know if a T-case from a 91 V-6 auto Trooper will fit on an 89 v-6 manual Trooper Any info would be gratly appreciated. I Would Like the flange style driveline mount instead of the slip yoke. will it work!!!
Thanks Robert <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: T-Case [Re: Roberts89trooper] #604171 05/17/05 08:03 PM
paulevans76 Offline
pretty sure I've read in another thread that you can swap over all the parts you need to convert to a fixed yoke. try the search. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Troop - Posing yard art
Re: T-Case [Re: Roberts89trooper] #604172 05/18/05 01:39 AM
JLEMOND Offline
the transfer case from the auto won,t fit the manual , but the parts you need to change to the fixed yoke will, which is only the rear half of the trans case, the part with the yoke on it , just unbolt the rear half and the yoke goes with it , should be enough room to swap it with out removing it from the veh Jerry
Re: T-Case [Re: JLEMOND] #604173 05/18/05 04:41 PM
Hey That Is what i wanted to hear. Thanks for the speedy reply it is much appreaciated.
Thanks Robert
Re: T-Case [Re: JLEMOND] #604174 05/18/05 11:32 PM
mlclark Offline
Isuzu Moderator
I'll default to Jerry on this one, but I think you have to also swap the cluster gear on the end of the main shaft for this to work. Something about a difference in the number of teeth?
Michael
Re: T-Case [Re: mlclark] #604175 05/19/05 02:13 AM
JLEMOND Offline
Yep you need to check the tooth count, there was a diff on some of these depending on the production date Jerry
Re: T-Case [Re: JLEMOND] #604176 05/20/05 07:01 AM
mlclark Offline
Isuzu Moderator
Thanks Jerry. I knew it was somethin' like that. <img src="/forums/images/graemlins/smile.gif" alt="" />
See, even a blind squirel finds a nut every now and then.
Michael (No offence intended towards visually impared rodents)
Re: T-Case [Re: mlclark] #604177 05/21/05 03:06 AM
JLEMOND Offline
none taken at all , fact is i just got back from the looking doc and one eye is better and the other is just a tad worse , hopefully a new pair of lookers will help take care Jerry
Re: T-Case [Re: mlclark] #604178 05/21/05 04:17 AM
mlclark Offline
Isuzu Moderator
That wasn't directed at you, Jerry. I was the blind squirel.
Nevermind...
Michael <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6269 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-06-07 00:49:33 UTC
