Cigarette Lighter Died Again #605096 05/20/05 06:07 AM
My cigarette lighter died about a year ago while using an air compressor plugged into it. I pulled it out and put a volt/ohm meter on it and found where it fried. I soldered it back together and it worked until last week when I plugged a power inverter into it and tried to use an electric staple gun.
Now my question, is the Trooper (95) a special lighter, or can I go anywhere like AutoZone and buy a generic lighter and replace it? <img src="/forums/images/graemlins/scared.gif" alt="" />
thanks,
michael
Re: Cigarette Lighter Died Again #605097 05/20/05 06:22 AM
onebadtrooper Offline
I'm pretty sure its a normal lighter. You could also get a 12volt power outlet( the same as the cig lighter) And wire it in somewhere else.
Re: Cigarette Lighter Died Again [Re: onebadtrooper] #605098 05/24/05 06:32 AM
Well, I went to Orilley's and AutoZone, and neither of them carry a lighter replacement. The plugs on it are a different size than the OEM.
So I broke out the solder gun and ran a very long bead to get it from point A to B, and put it back in. Now, there is no way the wire will burn again, but my Trooper might burn up.
I guess I am going to call St. Charles and see if I can get one from them unless somebody has an idea where else to get one?
thanks,
michael
Re: Cigarette Lighter Died Again #605099 05/25/05 12:09 AM
Smiley Offline
...unless somebody has an idea where else to get one?
Maybe a junkyard trip is in order?
[EDIT]
Either that, or maybe you could talk Mark (Wareagle) out of his... As I recall, he doesn't smoke anyhow. <img src="/forums/images/graemlins/smile.gif" alt="" />
[/EDIT]
Six Isuzus, so far... still have three of them.
Re: Cigarette Lighter Died Again #605100 05/26/05 11:39 PM
carsonmnc Offline
Radio Shack.. they have all the power goodies, even though they don't sell car stereo parts anymore <img src="/forums/images/graemlins/confused.gif" alt="" /> I would hardwire it to the battery with 14ga. wire and an inline fuse rated at a little above your inverter, because it uses the most juice you will most likely be pulling. Your inverter should have a built in fuse also, so you should be fine if you plug in an electric drill or circular saw <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5995 MB (Peak: 0.6626 MB) Data Comp: Off Server Time: 2026-06-13 10:54:19 UTC
