Auto Transmission Line Size/Temperature Sending Unit Install - 2001 Trooper? #605684 05/22/05 07:01 PM
8
88_Super_Trooper Offline OP
I will be installing a Temperature Sending Unit Manifold for my Transmission Temperature Gauge. It will be plumbed in-line on the metal line circulating fluid from the transmission to the cooler. I need to order the Manifold but I am not sure which size. I do not have a caliper handy. So, is it 3/8" or 5/16"? Also, which line is the pressure line and which is the return line? Thanks for your help.
You wouldn?t worry what people thought about you if you realized how little they did!
1988 Isuzu Trooper Limited, Bone Stock, 2.6L, 5 speed manual trany.
2001 Isuzu Trooper Limited, Bone Stock, 3.5L, Automatic.
Re: Auto Transmission Line Size/Temperature Sending Unit Install - 2001 Trooper? [Re: 88_Super_Trooper] #605685 05/23/05 02:57 PM
8
Seriously? No takers?
Re: Auto Transmission Line Size/Temperature Sending Unit Install - 2001 Trooper? [Re: 88_Super_Trooper] #605686 05/24/05 03:00 AM
JLEMOND Offline
the steel line on the right side of the trans closest to the front of the trans should be the press line,the rear most line is just a dump line back into the main case for the return of the cooled oil from the cooler , and the rubber line is between 5/16 and 3/8 u.s. sized line it is about 8-9mm in size for the steel line , you could splice into the rubber flex line right at the bottomof the radiator and use a high press thick walled hose ,be much easier than messing with the hard line Jerry
Re: Auto Transmission Line Size/Temperature Sending Unit Install - 2001 Trooper? [Re: JLEMOND] #605687 05/28/05 06:15 PM
8
Thanks for the response Jerry. I measured the metal line and it was very close to 3/8". I was thinking of putting the sender manifold right where the metal and rubber lines join up near the radiator. I was going to use a 3/8" compression fitting on one side of the sending unit manifold (for the metal transmission line) and a 3/8" barbed hose fitting on the other (for the rubber hose line). I figured that this setup would help support the sending unit manifold since it is brass and a bit heavy. I may just splice into the rubber line like you suggested and put a barbed 3/8" fitting on both sides of the unit. If I do this, do I need to go with different rubber hose or can I just use what it already there? Thanks for the input!
Re: Auto Transmission Line Size/Temperature Sending Unit Install - 2001 Trooper? [Re: 88_Super_Trooper] #605688 05/29/05 02:24 AM
JLEMOND Offline
The line that is on there now will be fine as long as it is in good shape , I just changed the press side line on my 2001, I used a short piece of 5/16 a.c. hose , alittle hard to push on but it will outlive the truck, starting to seep just a bit ,Jerry
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6085 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-11-16 08:42:21 UTC
