temp guage, how high?
#606324
05/23/05 11:55 PM
Hey guys, quick question. How far does the needle go on the temp for a 91 22re 4runner with a brand new toy 190 deg tstat and toy rad cap. Has new head and all. The temp it shows on the guage is a tad bit under half. Is this normal for that? I had a 89 v6 taco and the temp was always around 1/4 of the way up with a standard 180 degree t-stat I think. Just curious. The rad has corrossion in it, I put some of that flush stuff from prestone, drove it around and removed it, water looked dirty.
Re: temp guage, how high?
#606325
05/24/05 03:33 AM
Yep, just under half is normal in my 89 22re with the toyota 190 stat. In fact, I recently installed a 180 toyota stat and still sit just under 1/2... guess it's not that sensitive.
If you crank the heater in a cold day, you might notice the heat go a tad above 1/2 briefly, then cycle up and down slightly. This is normal with the stock T-stat which does not have a bypass for the coolant coming back from the heater core a bit cooler and closes slightly to compensate.
I'm moving to San Diego from Seattle in 2 weeks. Looking forward to some sun!! Even installed a sunroof last week... $8 from a pull-a-part here, like new. Guess they're not in much demand up here in the Pacific Northwest!
89 xcab 4x4 22re. 1.5" BJ spacers, 3" shackle and AAL + fender trim. 33x12.5 R15 MT/Rs, 15x10 rockcrawler streetlocks. 488 yukons by ZUK, detroit rear and true-trac front. 2 1/4" cat-back exhaust. Redline gear oil. Rear bumper by bentup.com.
[Re: Ben894x4]
#606326
05/24/05 06:56 AM
mine never rises above a 1/4 way but i think my gauge may be fubar
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: Ben894x4]
#606327
05/24/05 07:07 AM
sweeet man, you'll love the weather down here. Perfect beach weather right now. what part of sd are you moving to?
