slipping into 4wd??? #606494 05/24/05 04:03 PM
E
EricsTJ Offline OP
This question is for my 1994 Trooper 5 speed ...
Without warning (usually after making a turn) it makes an awful grinding sound as if you were trying to engage the 4wd while moving--the vehicle slows a little, and the steering shakes a little...I know this sounds strange...The 4wd works fine--it engages quickly,and disengages when you back up a few feet..
I disassembled both front hubs and they look fine--no visible signs of wear or metal shavings!The brake rotors and pads are fine. The lower ball joints boots are cracked and I'm sure need to be replaced.
Has anyone else had this happen??? <img src="/forums/images/graemlins/confused.gif" alt="" />
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: slipping into 4wd??? [Re: EricsTJ] #606495 05/31/05 11:36 AM
Daniel_T Offline
Your auto hubs are shot. Time to buy some manual hubs. Which you will like alot more anyways.
Later,
Daniel
"Thanks for the joy that you gave to me"
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5876 MB (Peak: 0.6360 MB) Data Comp: Off Server Time: 2026-11-16 08:54:42 UTC
