Page 1 of 3 1 2 3
3/4 Ton, Full Width Conversion (SAS V. II) #606673 05/24/05 11:28 PM
Ride Hard Offline OP
Well, im sitting around, waiting for parts, and dont have a single thing I can work on (besides grinding<img src="/forums/images/graemlins/rolleyes.gif" alt="" />), So I figured I'll post some pic's of my little project.
Right now, I have a wagoneer axle SUA (44) in the front, and the stock 44 in the rear, on 32" mtr's. (THESE ARE WHAT IM TAKING OFF)
I will be swapping in a Full-Float Dana 60 rear with a Detroit, and a SOA dana 44 front, with Hi-steer... Both axles are Full-Width, and have 5.38's.
I Also picked up some 35" BFG A/T's, on 16x8 rims.
I'm going to update this thread as I get it done, and want to get some good before/after pics... Should start taking off the old stuff in the next week or so, depending on when the DOM is finished
Anybody know where to get some BIG jackstand around denver? I was thinking flying j. <img src="/forums/images/graemlins/confused.gif" alt="" />
'93 Rodeo - Dana 60 FF Rear - Dana 44 Front - 35's
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606674 05/25/05 12:09 AM
paulevans76 Offline
looks like fun man. tractor supply places usually have some big ol' jackstands.
88 Troop - Posing yard art
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606675 05/25/05 09:15 AM
Bansil Offline
Harbor freight or Northern tools
both have 12/16 tons that are good.We have both stores here
shipping might kill ya though.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606676 05/25/05 02:15 PM
RobG Offline
so will you be changing out the wagoneer hubs for the 8-lug stuff to match the rear?
what are you doing about the width difference in the axles? or did you manage to pick up a CNC D60?
should be a good project though. definitely keep us updated!
-Rob
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: RobG] #606677 05/25/05 02:59 PM
Actually, I dont think I made my post 100% clear...
Im taking out the old wagoneer axle, and putting in a full width chevy, SOA up front...
The D60, and chevy D44 are the same WMStoWMS.
Yeah, 8lug hubs up front to match the rear.
Right now, Im trying to come up with a good design for a spacer for the spare tire mount, So I can put an 8lug wheel up there. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Thanks alot, I'm going to try and find a good tractor/trailor supply store today <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606678 05/25/05 04:55 PM
Starchild Offline
I was kind of thinking that might be the case since your pic shows both axles in the garage. <img src="/forums/images/graemlins/pfft.gif" alt="" />
That narrow width D44 didn't last very long up front, did it? Seems like you outgrew that thing pretty fast. <img src="/forums/images/graemlins/smile.gif" alt="" />
Good luck, and keep us posted <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606679 05/25/05 05:05 PM
RobG Offline
I had my 36x12.50 8-lug spare on my Rodeo's stock spare mount. All i had to do was cut off the little padlock "peg", use one of the stock lug holes and then redrill one other for the 8-lug pattern and secure with a nut on the back. pretty simple and worked just fine for years
-Rob
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Starchild] #606680 05/25/05 06:19 PM
Theres quite a few reasons im swapping the waggy axle out.
I needed to match the width of the rear Dana 60 I had gotten, And I wanted more lift for when I went to 35's
With my setup now, I can't turn the tires all the way to lock. They actually rub on the springs, And has tore up the inside of my front tires. It rubs on one of those little U shaped things that keep the springs stacked on top of each other.
Also, it doesnt sit quite as high as I would like, and is higher in the rear (than the front) so Im going to try and get it level. Besides, my 32's already rub I cant imagine 35s on a SUA setup.
Then theres always the clearance, and flex of SOA <img src="/forums/images/graemlins/evil.gif" alt="" />
Great idea Rob, thats what I will do... Which hole did you use, and where did you put the new one?? 10 and 2 O'Clock?
Anybody looking for an wagoneer axle for an SAS? <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: Ride Hard] #606681 05/25/05 06:47 PM
RobG Offline
going off memory, i think i used the 10 o'clock hole and then drilled a new hole roughly at 4-5 o'clock'ish. I then used the stock lug bolt and secured it with a lug nut on the backside. quick and simple.
-Rob
Re: 3/4 Ton, Full Width Conversion (SAS V. II) [Re: RobG] #606682 09/02/05 03:06 AM
FINALLY GETTING SOME STUFF DONE!
Got the front axle hung, and ready to go, minus steering. Looks like ill finally have to re-work the shackle hanger.
Im am LOVING the look, especially the width! <img src="/forums/images/graemlins/evil.gif" alt="" />
This is the best picture I could grab, my camera hates low light.
I hope to get the rear axle on there sometime this weekend! <img src="/forums/images/graemlins/smile.gif" alt="" />
Looks like it could be a close one when it comes to getting it out of the garage! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6440 MB (Peak: 0.7714 MB) Data Comp: Off Server Time: 2026-11-16 01:19:19 UTC
