Auto Transmission Lockup Problem
#607096
05/26/05 12:54 AM
I have an 87 4-runner w/ a motor that I just rebuilt. After I got all the engine bugs figured out....rough idle, O2 sensor wire, etc...I took it out for a spin. It seems as though the torque converter is not locking up when it should. The motor is reving to about 2000rpm before the trans. kicks in and the truck starts to move. It seems to be ok once the truck starts moving. A few times when I was at a stop (still in drive) I could feel the truck try to lurch foward like it locking up then. Anyone have any ideas on where to start with this problem? <img src="/forums/images/graemlins/confused.gif" alt="" />
1987 4-Runner with a "slightly modified" 22RE
Re: Auto Transmission Lockup Problem
[Re: Wildcat_4R]
#607097
05/26/05 02:36 AM
Is the fluid red and is it to the full mark?
[Re: ZUK]
#607098
05/26/05 03:45 AM
(shakes head in shame)
Wasn't filled up all the way...should have double checked.
[Re: Wildcat_4R]
#607099
05/26/05 05:30 AM
\ <img src="/forums/images/graemlins/cheers.gif" alt="" /> try pulling codes for the hell of it if you see the O/D blinking continuosly then nothing is wrong. i think a code 64 if a defective lock-up solenoid
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6015 MB (Peak: 0.6573 MB) Data Comp: Off Server Time: 2026-06-17 11:39:46 UTCValid HTML 5 and Valid CSS
