Page 3 of 4 1 2 3 4
Re: RSG - who's interested in less than 4 inches? [Re: Nukeiridium] #607446 06/09/05 12:36 AM
Dave Scott Offline OP
ron, i don't remember exactly what set-up you have, but if you also have the rear spacers, you shouldn't need airbags. and, the Eibach clone kit would fit just fine to give you 4" all around.
nuke, have you tried searching for a kit that would fit the MPV? if the coil height is the same or similar, compressed, on the Sportage as it is on the MPV, it should work relatively well, as long as there is a good way to mount them solidly.
Re: RSG - who's interested in less than 4 inches? [Re: Dave Scott] #607447 06/09/05 01:31 PM
wd8cdh Offline
Hi Dave,
I have stock springs all the way around and only FRONT spacers, not rear. The front spacers give me almost as much lift in the front as Eibach but I get more downward travel than I would have had with springs. In the rear, I am getting all of my lift from the airbags but I would prefer to get it from springs and only use the airbags as bumpstops and to compensate for payload.
I only want/need about 2" lift. I am running 30x950 tires.
Ron
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: RSG - who's interested in less than 4 inches? [Re: Nukeiridium] #607448 06/09/05 01:36 PM
wd8cdh Offline
Hi Nuke,
What is the inner diameter and free length of the MVP springs? I could probably find the correct bag to fit for you. Do the MVP springs turn in to a smaller diameter last coil on top and bottom like the stock springs?
By the way, are you running Green Diamond tires? Where did you get yours? I got mine from Hi-Tech.
Ron
Ron Schroeder
Long Island NY
Re: RSG - who's interested in less than 4 inches? [Re: wd8cdh] #607449 06/09/05 08:16 PM
Nukeiridium Offline
I'll try to get those measurements
How did you know I had green diamond tires? I got mine from hi-tec also smile I REALLY like them. How do you like yours so far?
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: RSG - who's interested in less than 4 inches? [Re: Nukeiridium] #607450 06/10/05 01:52 AM
wd8cdh Offline
Hi Nuke,
I thought I remembered them from an earlier post. Mine are A/T 30's, I think you got M/T 31's. I like them so far but I have not run them off road except in the sand. They were great in the rain.
The 30x950 really is as big as you can go with no trimming and no lift, at least with stock wheels. That's also why I don't want 4" lift. The 2.5" lift will really look great with 30's.
Ron
Ron Schroeder
Long Island NY
Re: RSG - who's interested in less than 4 inches? [Re: wd8cdh] #607451 06/10/05 02:00 AM
Nukeiridium Offline
Yeah, with more lift the 30" tires start to look too small smile
Re: RSG - who's interested in less than 4 inches? [Re: Dave Scott] #607452 06/29/05 06:26 PM
DaPeach Offline
So what's the status on these? Are they being produced...are they available? Was this just an interest check?
I'm checking into spacers for the stock springs...but I'd like to see some options for a small lift.
-Karri
2006 Jeep Liberty
1999 Sportage EX - for sale
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Re: RSG - who's interested in less than 4 inches? [Re: DaPeach] #607453 06/29/05 06:43 PM
maraguez Offline
I noticed that when the Kia is lifted, it tends to look lower on the rear right hand side. Dave gave me an explanation a while ago, but I was not clear on what he meant. After observing the rear of the Kia I figured that the only thing pulling the truck down on the side was the stabilizer bar. Everything else is A-OK. Does anyone have the same problem? If so, what did you do to correct the situation? It seems a lower bracket can be built, but maybe Dave has done that already and has one for sale. How about it Dave. Have not seen your name pop up for some time.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: RSG - who's interested in less than 4 inches? [Re: maraguez] #607454 06/29/05 09:46 PM
Calappoyas Offline
I bought Dave's rear panhard bar just for that reason.and well.... and for any future lifting I may add in the future. <img src="/forums/images/graemlins/notooth.gif" alt="" />
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: RSG - who's interested in less than 4 inches? [Re: Calappoyas] #607455 07/01/05 12:14 AM
when the rear end is lifted more than 1.5" (the height of the Eibach kit [so, they know this]) the rear axle is shifted to the passenger side. this causes the lean to the passenger side. only reason i can figure is that the extra tension on the bar pulls that side down a little. i don't make a bracket, but i do make a new, adjustable bar, check the vendor section for my prices (cuz i don't remember them right now).
as far as whether or not the shorter lift is being produced right now? no, it's not. that's the reason for this thread- to gauge interest.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6407 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-11-02 05:15:20 UTC
