SAS folks
#608203
05/28/05 10:25 PM
what are you doing with your master cylinder? stock 1"? with rear disks, there is no way what i have will work. i want a chevy, but they are too long. the windshield wash bottle is in the way on 95-96 trucks. i guess i need to find a smaller bottle and retrofit it in, so i can put the chevy master in. i put the 1" T100 master on teh 4runner since i also put the bigger T100 calipers on the 4runner.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
Re: SAS folks
[Re: surlynkid]
#608204
05/29/05 03:19 PM
Stock. The 5speed has made it agreeable to leave it that way.
I've been trying to think how you could relocate it. Got room in front of your battery? Otherwise I think your plumbing will be a mile long.
~Adam  96 T100: D44, lockers and stuff
Re: SAS folks
[Re: adam]
#608205
05/30/05 04:29 AM
in 1997 Toyota put the wash bottle in a worse spot, right in front of the passender side wheel well, perfect spot to rip it off with a fully flexed SAS T100
Re: SAS folks
[Re: adam]
#608206
05/30/05 04:39 AM
I've been trying to think how you could relocate it. Got room in front of your battery? Otherwise I think your plumbing will be a mile long. can you lock up the tires without any problems? the 1997 wash bottle location sucks for SAS with my custom winch bumper. i am thinking about a small 88 4runner bottle in teh same spot as teh 1995-1996.
Re: SAS folks
[Re: surlynkid]
#608207
05/30/05 03:49 PM
can you lock up the tires without any problems? I've had two occasions I can remember where I needed to, and it did. The pedal was pretty close to the floor, though. So it did it without any problem, but I can't say I liked it.
Re: SAS folks
[Re: adam]
#608208
05/30/05 04:04 PM
Then there is always the 50's style rubber bag idea... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: SAS folks
[Re: Jake97T]
#608209
05/31/05 02:35 PM
There is a serious lack of pictures in this thread. <img src="/forums/images/graemlins/smile.gif" alt="" />
Brian K. Gallus I have nothing important to say.
Re: SAS folks
[Re: bkg]
#608210
05/31/05 04:57 PM
Toyota Moderator
You could try to find a Toy style 1-1/16" bore and see how you like it. You'll probably be happiest with a 1-1/8" though, aside from having to figure out the washer res. problem.
Re: SAS folks
[Re: ErikB]
#608211
05/31/05 11:08 PM
You could try to find a Toy style 1-1/16" bore and see how you like it. You'll probably be happiest with a 1-1/8" though, aside from having to figure out the washer res. problem. those were only in teh 1 ton, correct?
Re: SAS folks
[Re: surlynkid]
#608212
06/01/05 08:57 PM
Toyota Moderator
Not necessarily. Supposedly it was on all the ABS models, but I've seen it ones w/ and w/o ABS. I dunno what the real qualifications of having the bigger bore were.
Technically, I'd think the 1-ton would have the smaller bore to give better braking power. I saw a 1-1/16" in the JY on a 2wd T, so maybe that's a good place to start looking? It would make sense to reduce the braking power/leverage on a (somewhat lighter?) truck with smaller tires.
I know Brandon Miller found a 1-1/16" in some Toy car in the junkyard and used that. Sorry I can't be more helpful/specific though.
