2000 montero sport 4x4 #608386 05/29/05 09:03 PM
my montero transfer case 4x4 light continues to blink after i have disengaged transfer case i have replaced the switch that indicates the t-case is engaged and when i shift to 4 to 2 wheel drive the t-case disengages but the light continues to flash. what could cause this? also at low rpm it sounds like it wants to reengage the t-case. can anyone help or point me in the right direction?
Re: 2000 montero sport 4x4 #608387 05/30/05 04:24 AM
LRJ4x4 Offline
There is not a lot of third generation Montero owners on the board. Have you tried pulling the codes from the computer? You need a OBDII reader from a auto parts store. Sometimes they will loan one otherwise there around $100.
Re: 2000 montero sport 4x4 [Re: LRJ4x4] #608388 05/30/05 12:43 PM
yes did that first because code siad transfer selector switch was bad
Re: 2000 montero sport 4x4 #608389 05/30/05 01:46 PM
W
wyleone Offline
Just because the code said that, doesn't mean the switch was at fault. It is likely there is a module that receives the info from the switch, so the wiring and that module are also possibly at fault. Time to get a wiring schematic for the circuit, maybe ask a tech at your local Mitsu dealer what is the more common fault. If you can, (if available) get a code diagnosis flowchart, It will show the proper steps in diagnosing the problem. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2000 montero sport 4x4 #608390 05/31/05 02:57 PM
conner Offline
What code number did you have?
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 2000 montero sport 4x4 [Re: conner] #608391 05/31/05 05:21 PM
DC Offline
Mines been blinking for the ppast 4 years. It's nothing. You know your not in 4wd when the transfer shifter is out. I love manual transfer cases.
DC
97Sport A/T 33's
locked front & rear 4.90
5" IFS Lift
Re: 2000 montero sport 4x4 #608392 06/06/05 02:56 PM
2000ute Offline
Question: have you recently done a water crossing or gotten really muddy? This is usually the only time I have this sort of issue, with my light blinking. It always goes away after a thorough undercarraige cleaning. <img src="/forums/images/graemlins/confused.gif" alt="" />
Used to have a custom 2000 Montero Sport - Front & Rear bumpers, Sliders, Warn m8000, 33/1050/15 BFG MT's
Now own a 1998 Toy 4Runner 3.4 Limited stock
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6112 MB (Peak: 0.6886 MB) Data Comp: Off Server Time: 2026-06-20 21:41:48 UTC
