How can you tell a CV joint is going bad on a Trooper? #608877 05/31/05 03:09 AM
Z
Zaphod Offline OP
2000 Trooper LS. Stock in all repects. 59K miles.
I'm noticing some vibrations when I'm accelerating. Comes and goes, normally around the same speed/RPM.
Last time I noticed this was on my '89 Honda Prelude, and it meant bad CV joints. Is it the same for the Trooper?
Any ideas what it costs to fix, and what mileage I should expect them to go bad? I don't do any extreme off-roading.
Does the Trooper even HAVE CV joints? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks!
Re: How can you tell a CV joint is going bad on a Trooper? [Re: Zaphod] #608878 05/31/05 04:05 AM
sweater Offline
I wouldn't expect this to have anything to do with the CV's, but more likely the driveshaft. Is there any play in the carrier bearing? When was the last time the joints have been serviced? (greased?)
As far as I know, the front CV's (yup, you have them) are not turning with power to them when in 2wd to cause any shudders.
- Mike
Re: How can you tell a CV joint is going bad on a Trooper? [Re: sweater] #608879 05/31/05 04:23 AM
Z
Zaphod Offline OP
Uh....... er....... <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
What's a carrier bearing?
As for the last time the joints were greased, I have no idea. Certainly not since I bought it a year ago.
Re: How can you tell a CV joint is going bad on a Trooper? [Re: Zaphod] #608880 05/31/05 11:30 AM
Daniel_T Offline
Carrier bearing is located on the rear drive shaft. It is mounted to your rear crossmember. They only use these when you have a rear 2 piece drvie shaft..
Later,
Daniel
"Thanks for the joy that you gave to me"
Re: How can you tell a CV joint is going bad on a Trooper? [Re: Daniel_T] #608881 05/31/05 12:13 PM
Z
Zaphod Offline OP
Man, I'll have to look when the rig gets out of the body shop later this week. (Had a rather unfortunate meeting with a guardrail in Augugust while dodging a deer near Syracuse. 99% cosmetic, fortunately.)
I'll let you know! Thanks!
Re: How can you tell a CV joint is going bad on a Trooper? [Re: Zaphod] #608882 06/05/05 05:51 AM
K9Troopin Offline
Partial Answers:
Bad CV = Clicking while the wheel is turning, I think it clicks more as you turn in the direction of the damaged CV.
Vibrations = LOTS of stuff. Just have to run it's location down. But with the two piece Driveshafts, as has already been mentioned, you get lots of vibration especially with lifts due to the increased angle. But even with stock driveshaft you get the wonderful shaking.
The carrier bearing and the three "U-joints" that make up your two-piece driveshaft need lubing and monitoring. When they get old and worn (like mine just last week) they cause a WHOLE lotta shakin! And you'll know sumthin is up. I had the two end U-joints and the carrier bearing replaced. It is back to only rattling during quick take offs from a stop...as "quick" as you can get with our power houses! <img src="/forums/images/graemlins/lol.gif" alt="" />
Good luck
Dana
'91 LS Trooper~ 1.5" Susp. & 3" Body Lift, 33"BFG M/Ts, custom double sliders, Indy4x bumper,Herc'd lower body panels, Hella 550 lights, custom rear shelf and speaker box, customized console, blue grill strobe lights and wig-wag headlights
Re: How can you tell a CV joint is going bad on a Trooper? [Re: K9Troopin] #608883 06/05/05 08:20 AM
F
Frisky Offline
Just a note about the CV's ona newer 4WD, they do spin while driving on a shift on the fly setup, but the transfer case does not apply power to the front wheels unless your button is pressed for 4WD. Newer SOTF systems have stock flanges that lock the hub/wheel to the CV while driving. This allows the front diff to be spinning at the same speed as the transfer case when the 4WD is engaged, thus it can be done "on the fly"
Just wanted to clarify that. <img src="/forums/images/graemlins/smile.gif" alt="" />
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6226 MB (Peak: 0.7138 MB) Data Comp: Off Server Time: 2026-06-07 03:14:00 UTC
