If your timing is off will it throw a cheak engine light?
#609902
06/02/05 01:28 PM
Toyota master
Re: If your timing is off will it throw a cheak engine light?
[Re: thecat]
#609903
06/03/05 12:26 AM
Toyota Moderator
What year vehicle and which engine?
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
[Re: Dandeman]
#609904
06/03/05 01:39 AM
Toyota master
[Re: thecat]
#609905
06/03/05 03:06 AM
yeap the engine being out of time will cause a hole bunch of problems that he computer will throw codes for
[Re: thecat]
#609906
06/03/05 03:22 AM
[Re: thecat]
#609907
06/03/05 04:02 AM
Toyota Moderator
All cars and light trucks built and sold in the United States after January 1, 1996 are required by federal law to be OBDII equipped, which includes your 3.4L engine.
And on an OBDII equipped engine, the engine computer (or ECU) has total control of the ignition timing.. and there is no way for you to set or adjust it..
Go to an Autozone or one of those places that lets you use an OBDII scanner for free and read out the error codes that have turned on the check engine light.. and post that info here..
That will give some idea what the problem is..
[Re: Dandeman]
#609908
06/03/05 03:31 PM
There is no light yet but something is deffinantly off. I have no power over 3K rpms.
Toyota master
[Re: thecat]
#609909
06/04/05 05:04 AM
Pull the tube off the t'body and see how much carbon buildup you have; might be time for a good little tuneup. Just a thought.
[Re: kewlynx]
#609910
06/04/05 07:18 AM
Tune up? I have replaced the spark plugs, spark plug wires, throttle position sensor, all the vacume lines, cleaned the entire intake down to the block, cleaned the maf. I am out of ideas. A V8 swap is starting to sound really good at this point.
Toyota master
[Re: thecat]
#609911
06/06/05 03:39 AM
You have cleaned the air intake, installed new plugs spark and the gas? Gas filter or something might be restricting the fuel to the engine is my guess. Good luck.
