95 T100 engine #609920 06/02/05 03:51 PM
swflt100 Offline OP
Is the 3.4v6 in a 95 T-100 and a 03 Tundra The same motor ??? The reason I ask is aguy totaled his Tundra and its headed to the junk yard but all the damage is from the cab back and i can pick up The engine complete for $500.00
with only 14,000 miles on it.. So is it a direct replacement?? Or would i need The 03's ECM???
Real trucks get dirty,scratched & used..
Re: 95 T100 engine [Re: swflt100] #609921 06/02/05 08:22 PM
H2O_MAN Offline
The engine is the same. The electronics and accessories differ.
Re: 95 T100 engine [Re: H2O_MAN] #609922 06/02/05 09:35 PM
swflt100 Offline OP
So it would not be a direct replacement??
Re: 95 T100 engine [Re: swflt100] #609923 06/03/05 03:26 AM
kewlynx Offline
Strip stuff off the long block and put it on your donor long block, and you're set to drop it back in. Easier to do this stuff with a pair of engine stands, rather than cussin about stuff while in the engine compartment. You can always post down in the parts bin to sell what you don't want when you're done. <img src="/forums/images/graemlins/kewl.gif" alt="" />
HOWEVER, I'd do a compression and/or leakdown test on the donor before you start to make sure it's still okay. Just a thought.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6006 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-11-02 19:24:51 UTC
