Towing miles add up #610292 06/03/05 04:08 PM
flyfishingjeep Offline OP
I just completed our first trip towing the 99 TJ with our motorhome. I had the xfer case in neutral and the ignition was set to keep the steering wheel unlocked.
Jeep towed great but the towing racked up miles as it was being towed, I didn't think this was suppose to happen on a Wrangler. Have I missed a step or what can I do to prevent the towing miles?
Thanks for any input, Ken.
Re: Towing miles add up [Re: flyfishingjeep] #610293 06/03/05 05:14 PM
BigJim Offline
Yeah they got smart and put the output on or near the tailshaft of the transfer case. If you do not want the miles unplug it while towing. I think you would have to reconnect when driving though.
Re: Towing miles add up [Re: flyfishingjeep] #610294 06/07/05 05:19 AM
Disconnect either the rear driveshaft or the speedometer cable/sender.
Re: Towing miles add up #610295 06/12/05 02:01 AM
Does the TJ have a speedometer cable or is it electronic. I was thinking if it happens to be electronic that one of those quick battery disconnects might work.
Re: Towing miles add up [Re: flyfishingjeep] #610296 06/18/05 05:11 AM
NCBBA2358 Offline
Easy way to figure that one out.... Look underneath and see if there is a beefy cable thing coming out of your transfer case... If there is some sort of wired deal, you will or should know.... Or you could pull your neg. battery cable and test it by towing....
There should be a clicking plastic boot on the back of your dash that you can easily undo and it should keep the miles from racking up....
Re: Towing miles add up [Re: NCBBA2358] #610297 06/19/05 05:26 AM
BROWNBAGG Offline
put it on a trailer
Re: Towing miles add up [Re: flyfishingjeep] #610298 06/19/05 09:32 PM
Ok, it IS lectronic and leaving the key in the ignition to keep the steering wheel unlocked did power the electronics and added miles while towing. I installed a disconnect at the negative battery terminal so I can kill power while towing. Works Great.
Re: Towing miles add up [Re: flyfishingjeep] #610299 06/20/05 02:36 AM
NCBBA2358 Offline
GROOVY!, sir of the middle TN people! head out to the beach some time with your new working plan and put some sand miles on that thing!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6149 MB (Peak: 0.6962 MB) Data Comp: Off Server Time: 2026-05-29 16:07:51 UTC
