What winch should I buy? #610564 06/04/05 08:12 AM
mudking82 Offline OP
I am looking to get a winch for my 88 Toyota pickup. I have looked at the new T-Max winches, as well as many others. Anyone have experience with the T-Max? Is there honestly really much difference in quality in brands-Warn, Ramsey, Milemarker, T-Max? Has anyone ever put a brand other then Warn on a Warn Combo kit mount front bumper? Thanks for any help. [color:"black"] [/color]
Re: What winch should I buy? [Re: mudking82] #610565 06/04/05 06:08 PM
Monty n Guate Offline
Well I have a Ramsey 8000lb on a multi mount system supplied by MM It seems to work well. I like being able to remove it when I don?t need it.
Don Iler
97 4cyl. Tacoma
OME 881s, N91s, Alcan AALs, Rancho 9k rear shocks
4.56 gears
32x11.50 Procomp ATs
Re: What winch should I buy? [Re: Monty n Guate] #610566 06/05/05 07:00 AM
SHAD Offline
No experience with milemarker or T-maxx or any winches in general I have seen one Warn M8000 break it planetary gearing trying to tow my old 4 runner up a hill and know a guy who had his warn HS9500 burn up it's motor up on a jeep.
I have a Magnum 9000 it's made by warn mostly warn parts. I haven't used it yet but I'll see how it holds up.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: What winch should I buy? [Re: mudking82] #610567 06/05/05 11:17 PM
Aaron84x4 Offline
i would like to see which ones are the best as well. i have heard a lot of good things about warn, but yea if there is a quality one for cheaper, let me know! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: What winch should I buy? [Re: Aaron84x4] #610568 06/06/05 04:12 AM
J94_4runner Offline
I was looking at a milemarker. not sure the model.. forget off hand. but I could get one to the door for about $450:) I think it's the 8 or 9 lb model. My buddy had some issues with is top of the line Warn. some kind of internal short. Warn ended up fixing it for him, but it was a PITA.
www.celicasupra.com
Re: What winch should I buy? [Re: J94_4runner] #610569 06/06/05 10:36 PM
G
Germ Offline
I've had a Warn M8000 now for about 10 years, and it has alway's worked well for me. I counter-spun the motor once by trying to pull with the truck with the winch line attached. (won't do that again <img src="/forums/images/graemlins/shiner.gif" alt="" />) cost me about 125 to fix it, but since then the winch has been perfect.
When I got my new truck (85 4Runner) it had the M8000I, and the dude who had it before me soaked the thing, and the motor is corroded, and the planetaries are rusted. Prolly gonna cost more than it's worth to fix.
Personally, I think all the winches are fairly good. If you treat them well, they should work fine. I'd grab the $450 winch, and use it.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
Re: What winch should I buy? [Re: mudking82] #610570 06/07/05 04:01 AM
I have a 8000 milemarker on my truck with a warn mounting plate and the bolt holes lined up perfect and i haven't had any trouble from the winch, it has pulled me a few times with ease
Re: What winch should I buy? #610571 06/07/05 05:36 AM
Thanks for all the info guys. I still don't know what one to get yet, big decision, so I have to compare all the specs.
Re: What winch should I buy? [Re: mudking82] #610572 06/07/05 09:26 AM
MM & Ramsey have very slow line speeds compared to Warn.With any electric winch just remember to give the motor time to cool if it get's hot and they should give you years of trouble free work.
Re: What winch should I buy? #610573 06/08/05 07:08 PM
Yaker Offline
The T-Max is garbage! My buddy has a 12500 on his cab truck and it sucks. That thing has never worked right even out of the box. I've had to pull that huge thing out with my little Yota twice when that thing craped out. The bolts that hold the hole thing together(the moter, spool, and siloniod) want even stay together.
As for MM and Ramsey there just slower. Now the nicer Ramseys are preety comparable to the Warn.
Work smart not hard!
83 SR5 Pickup, 4" home brew lift, 36 inch TSLs ,locked front and rear, 4.7 t-case gears, 5.71 diff. gears, cross over high steer, 8k warn, custom bumper and flat bed, and huge plans.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6277 MB (Peak: 0.7350 MB) Data Comp: Off Server Time: 2026-07-09 17:52:18 UTC
