cel 14 ignition signal
#610775
06/05/05 03:25 AM
Truck will not idle right, was running fine until this morning. Went to start it and engine ran for a few minutes, I stepped on gas when it started to idle low and the engine shut off. I measured resistance at Primary Coil and Secondary Coil they both checked out OK. Inspected spark plugs reset gaps. Replaced Fuel Filter Cleaned TB
Any ideas what else I can look at. <img src="/forums/images/graemlins/confused.gif" alt="" /> Thanks,
gcinque 03 Tacoma Xtra cab 4cyl 5spd 89 4Runner/Jasper reman 22RE/Auto SOLD 98 Tacoma Xtra cab 4cyl Auto SOLD
Re: cel 14 ignition signal
[Re: gcinque]
#610776
06/05/05 04:13 AM
Did your mass air flow wire harness come off by any chance? Will it still start and just do the same thing?
[Re: mudking82]
#610777
06/05/05 02:07 PM
The MAF harness didn't come off, but I did check resitance on it and also checked the EFI main relay again both checked out ok. Will it still start and just do the same thing?
Do you mean start it with the MAF unplugged?? I never thought of that, I'll try it. Thanks,
[Re: gcinque]
#610778
06/05/05 08:26 PM
CEL- code 14....
You will find youe problem in the wiring leading to the igniter from the ECU or in the 2 wire between the igniter and distributor. More than likely the 3 wire crossing over the valve cover to the igniter though. Check the connections at the plug and then do a check of the wiring itself for damage/continiuity. Alot of times this wiring gets pinched or makes contact with the exhuast manifold and burns. Code 14 basically means that the ECU isnt getting the trigger signal from the igniter...resulting in the ECU killing the injectors.
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-06-09 21:50:35 UTCValid HTML 5 and Valid CSS
