cel 14 ignition signal #610775 06/05/05 03:25 AM
gcinque Offline OP
Truck will not idle right, was running fine until this morning. Went to start it and engine ran for a few minutes, I stepped on gas when it started to idle low and the engine shut off.
I measured resistance at Primary Coil and Secondary Coil they both checked out OK.
Inspected spark plugs reset gaps.
Replaced Fuel Filter
Cleaned TB
Any ideas what else I can look at.
<img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks,
gcinque
03 Tacoma Xtra cab 4cyl 5spd
89 4Runner/Jasper reman 22RE/Auto SOLD
98 Tacoma Xtra cab 4cyl Auto SOLD
Re: cel 14 ignition signal [Re: gcinque] #610776 06/05/05 04:13 AM
mudking82 Offline
Did your mass air flow wire harness come off by any chance? Will it still start and just do the same thing?
Re: cel 14 ignition signal [Re: mudking82] #610777 06/05/05 02:07 PM
gcinque Offline OP
The MAF harness didn't come off, but I did check resitance on it and also checked the EFI main relay again both checked out ok.
Do you mean start it with the MAF unplugged?? I never thought of that, I'll try it.
Thanks,
gcinque
Re: cel 14 ignition signal [Re: gcinque] #610778 06/05/05 08:26 PM
Esquire812 Offline
CEL- code 14....
You will find youe problem in the wiring leading to the igniter from the ECU or in the 2 wire between the igniter and distributor. More than likely the 3 wire crossing over the valve cover to the igniter though. Check the connections at the plug and then do a check of the wiring itself for damage/continiuity. Alot of times this wiring gets pinched or makes contact with the exhuast manifold and burns. Code 14 basically means that the ECU isnt getting the trigger signal from the igniter...resulting in the ECU killing the injectors.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6019 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-06-07 08:30:45 UTC
