No Brakes !!!!!!!!!!!!!!!! #611632 06/06/05 06:27 PM
Ok heres the deal I got stuck at our lake and I mean really stuck <img src="/forums/images/graemlins/evil.gif" alt="" />! after 2 trucks and an international scout tried to pull me out w/ no luck, <img src="/forums/images/graemlins/frown.gif" alt="" /> ,we finaly got her out w/ a wrecker <img src="/forums/images/graemlins/shiner.gif" alt="" />.So on the way home I noticed that my brakes were way to to easy to push,not good,and you could hear a little hissing noise. And now I have no parking brake at all so what should I look for or should i just take them to a shop.Any advice would be helpful
Re: No Brakes !!!!!!!!!!!!!!!! #611633 06/06/05 11:16 PM
G
Germ Offline
A little info about the truck would help...
I would first make sure everything is cleaned out **REALLY*** well. Pull the back drums and clean it out with water first then some brake cleaner.
I would also check all your brake lines. While it's never happened to me, I would think the force of being pulled out could have bent/cracked one of your hoses or metal lines, and you have a small leak. Check first around the wheels, and trace the lines up.
Have a buddy step on the brakes while you crawl around and see if you can find the source of your "hiss". Prolly find a small leak there.
good luck
Erik <img src="/forums/images/graemlins/cheers.gif" alt="" />
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
Re: No Brakes !!!!!!!!!!!!!!!! [Re: Germ] #611634 06/09/05 05:42 PM
fourwd1 Offline
A "hiss" would indicate a vacum leak in the booster or it's vac line, but that would make the pedal hard, not soft.
Fluid leaks don't usually make noise, and the resevoir will be low, and there'll be a puddle.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5906 MB (Peak: 0.6438 MB) Data Comp: Off Server Time: 2026-07-09 17:53:06 UTC
