2000 3.5 V6 HELP #612030 06/07/05 01:37 PM
fourwd1 Offline OP
Cracked head at cyl #3 at only 37K mi. It's out of warranty so a local shop with a very good rep replaced the head. They had some problem setting timing until they found the TSB on timing belt. BUT, now it has a flashing CEL, code is mis-fire cyl #4 - lean (not the replaced head, the other side they didn't touch). Also Random Mis-fire code at times.
They reset the timing belt numerous times, swapped plug, coil,and even injector between cylinders but error stays at #4. FWIW the compression on #4 is 10# lower than the other 5, but w/in spec.
They're at their wits end, anyone have an idea ?
Thanks.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 2000 3.5 V6 HELP [Re: fourwd1] #612031 06/07/05 09:36 PM
fourwd1 Offline OP
BTW,it didn't have this problem before it when into the shop.
Re: 2000 3.5 V6 HELP [Re: fourwd1] #612032 06/08/05 12:34 AM
tinytrooper Offline
If the ecm has stored a hard code, then it needs to be reset correctly to clear the light and relearn the fault.
Since your truck is obdII I'm not sure a generic scanner can completly reset the comp. correctly enough to let the ecm resume learning.... this may not matter but just a thought
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5947 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-05-29 23:50:14 UTC
