Bye-Bye old transmission, Hello new transmission. #612500 06/08/05 05:47 PM
V
vovkus Offline OP
Just got phone call from my dealership. They drop the pun on the transmission and found some metal parts in it. I was questioned about what I did with Trooper, because dealership installed a new transmission just in October 2004.
"Nothing special" was my answer. No towing. No over 80 Mph driving.
Now I start thinking about what I will do when warranty will be over.
I hope they will install a new tranny before holidays. Last time it takes 3.5 weeks.
I thing the reason for failure was incorrect ATF level. I did not checked it when new tranny was installed. This time I will check everything.
2001 Trooper LS 3" lift,no more Rancho 9000RX,
no more 4L30E transmission,
ProComp 8" 130W driving lights,
Surco roof rack (modified),
110V power outlet, Viair 380C compressor,
CB/FRS/GPRS/HF/VHF/UHF Radio, 285/75/16 BFG AT/KO.
Re: Bye-Bye old transmission, Hello new transmission. [Re: vovkus] #612501 06/08/05 08:30 PM
Z
Zaphod Offline
Yikes! <img src="/forums/images/graemlins/scared.gif" alt="" />
Dude, that sucks! <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Bye-Bye old transmission, Hello new transmission. [Re: vovkus] #612502 06/08/05 11:35 PM
holger Offline
Vlad, that's bad, really bad !
I had a hope that we will wheel together these holidays. I am not sure that they will be able to replace the tranny by holidays <img src="/forums/images/graemlins/confused.gif" alt="" />
Let's see how this replacement will go on.
Oleg
Deceased Rodeo'02 4WD.
Re: Bye-Bye old transmission, Hello new transmission. [Re: holger] #612503 06/09/05 12:23 AM
V
vovkus Offline OP
They promised 2-3 days, but this is a dealer promise smile
Hope everything will be ok and I'll get trooper back soon.
Re: Bye-Bye old transmission, Hello new transmission. [Re: vovkus] #612504 06/09/05 12:34 AM
lttlbddy Offline
Exactly which 'holidays' are you referring to? Some Ukrainian thing that I am not aware of?
Good luck on the quick fix though. Steve G
Re: Bye-Bye old transmission, Hello new transmission. [Re: lttlbddy] #612505 06/09/05 12:49 AM
V
vovkus Offline OP
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />4th of July <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Bye-Bye old transmission, Hello new transmission. [Re: lttlbddy] #612506 06/09/05 01:05 AM
holger Offline
exactly. This is a very special Ukranian holiday. This day, July 4, 1776, Ukranians got a new country to visit and to work in <img src="/forums/images/graemlins/smile.gif" alt="" />
Oleg
Re: Bye-Bye old transmission, Hello new transmission. [Re: holger] #612507 06/09/05 04:30 PM
lttlbddy Offline
I salute you <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Enjoy . . . hopefully with a healthy transimission. SG
Re: Bye-Bye old transmission, Hello new transmission. [Re: lttlbddy] #612508 06/15/05 07:20 AM
V
vovkus Offline OP
Warranty is a good thing, but it is not forever.
So, second transmission in 4 years it is too much. What can be a root of the problem?
1. 33" BFG?
2. Transmission cooler? May be the level of cooler is too high?
3. Incorrect level of ATF. I did not check the level, when new transmission was installed. And the quality of work was so bad. Some bolts was loosen, and some of them even not exists.( This time I will check everything).
4. Powertrain Control Module (PCM) failure?
5. Just my luck?
If it will broke again, I think dealer will refuse the warranty. I do not want to be in that situation.
Re: Bye-Bye old transmission, Hello new transmission. [Re: vovkus] #612509 06/15/05 12:17 PM
Richard Saylor Offline
The biggest thing is the ATF level. You've got to make sure it's correct. Too high or too low, and you risk damage. Just make sure that it's correct, and it should last a long time. Then again, it could just be your luck. <img src="/forums/images/graemlins/nana.gif" alt="" />
Here's to good luck with the new one. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6424 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-06-07 06:07:47 UTC
