22r-e TDC #613564 06/11/05 09:46 PM
casper3t Offline OP
does the dimple on the cam spocket points to 6 and on the crankshaft it points at 12?
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: 22r-e TDC [Re: casper3t] #613565 06/12/05 12:40 AM
mosk Offline
The crank should be at TCD (using the timing mark on the oil pump cover), and the cam dowel pin should be pointed to 12 o'clock. This should place the dimple in the cam gear not-quite-at 12 o'clock, IIRC
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: 22r-e TDC [Re: casper3t] #613566 06/12/05 01:25 AM
kewlynx Offline
Mosk is right; dimple slightly left.
MORE READING here. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 22r-e TDC [Re: casper3t] #613567 06/12/05 07:38 AM
BennyBoy Offline
No, Reverse. Crank mark down, Cam Key up with mark about 5* left of 12 o'clock.
Re: 22r-e TDC [Re: BennyBoy] #613568 12/10/06 05:08 PM
ChrisH Offline
22re; 22r-e; 22 re; 22r; 22-r; 22-re; Timing; Top Dead Center; TDC
set the number 1 piston to Top Dead Center (TDC) on it's compression stroke. To do this, I used a 19mm socket on my breaker bar and rotated the crank bolt clockwise until the notch on the crank pulley lined up with the "0" mark on the oil pump cover.
When the number 1 piston is at TDC and on the compression stroke, both of the intake and exhaust rocker arms should be loose (in the picture I am actually able to slide rocker arms off the cam lobe - this is loose).
If they are not both loose, you must rotate the crankshaft bolt 360 degrees since you are not on the compression stroke.
easiest way i've found to do it. just thought i'd ammend this thread smile
edit: yet more good techniques:
JeffsToyo:
TDC of the firing stroke..The piston is at TDC twice with the #1 spark plug removed, put your finger over the hole as you turn the motor over and when you feel the air being pushed out you are at TDC on the firing stroke. You could remove the valve cover also and check for clearance with the #1 rocker arms to see.
Good luck
Jeff S.
42D22R:
Alternatively, if you ain't got someone to help you, stuff a small piece of paper towel in the #1 spark plug hole, turn the motor over just a little at a time until the paper towel pops out, then line up the timing mark on the crank with the 0* mark. She should fire right up if you stab the distro in on #1, then throw the timing light on smile
Good luck
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6082 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-06-07 07:22:53 UTC
