LSPV Brake issues #614371 06/13/05 07:38 PM
A
averkam Offline OP
I have read a lot of stuff about this Load Sensing brake prop valve. It is a great idea if it works. Mine does not.
I have adjusted it all the way down, all the way up (tied it to the frame). Reworked an verified function of the rear brake mechanicals. The brakes are adjusted and will self-adjust. My e-brake works great but I get very very little rear braking. If I am lucky I can get the rear wheels to lock up on ice.
Normal driving is not so bad but towing my boat is not so good. What goes wrong with these things and how do I check/rebuild/clean it out so that it functions correctly.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: LSPV Brake issues [Re: averkam] #614372 06/13/05 07:46 PM
4Crawler Offline
Re: LSPV Brake issues [Re: averkam] #614373 06/13/05 10:43 PM
Robinhood150 Offline
Do you have rear ABS?
On a side note, you don't want them to lock up before the fronts do, otherwise you'll be swapping ends pretty quick.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: LSPV Brake issues [Re: Robinhood150] #614374 06/13/05 11:51 PM
Spacetrucking Offline
Yeah, a friend of mine rolled his Runner on account of rear brake lock-up, but then he was not used to the truck yet, was new to him.
I purchased a Wilwood manualy adjustable valve.
Will be installing it later this summer with new routing, etc.
I also can lock up the rear un slippery surfaces.
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: LSPV Brake issues [Re: Spacetrucking] #614375 06/14/05 02:28 AM
A
averkam Offline OP
Thanks for the info. Mine is just way out of adjustment.
Re: LSPV Brake issues [Re: averkam] #614376 06/14/05 11:55 AM
foxtrapper Offline
Many times they are sludged up internally and therefore inoperable. While the FSM shows them as being a non-serviced part, they are in fact easily disassembled and cleaned.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-05-30 01:06:34 UTC
