LSD seems to be sticky.? #615216 06/16/05 07:51 AM
hd77303 Offline OP
Howdy once again. The search tool is insane, I spent two hours last night looking for something so hope this is not a re-post.
My LSD seems to be hanging up when stopped at an intersection.
Go to make a hard turn and you can feel it bind up and or tweak the rear wheels.
Any ideas out there?
Thanks
KKD
3 rides, 1 smashed, 2 with bad motors, going to rebuild it he says, going to try!
Hate to say it. Never have time and money together. The raiders all of them are available.
Parts or whatever you want.
Bought a Chevy Colorado 2005 Crew Cab Z71 4x4
Re: LSD seems to be sticky.? [Re: hd77303] #615217 06/16/05 08:38 AM
DanWheeler Offline
search tool sucks. use "+" symbols to search multiple terms. Not like google or anything else halfway normal.
You're LSD... let me guess, you recently changed the diff fluid? If so, you may not have put in the friction modifier. You can find some at your local parts store. I use Redline. There are a few different brands out there. No idea if it matters or not. I put in half the recommended amount to keep it sticky off-road. It's not as comfortable on-road though. oh well. A little chatter aroudn tight corners is normal with the LSD.
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: LSD seems to be sticky.? [Re: hd77303] #615218 06/16/05 12:22 PM
BINGO ! we have a winner add some posi additive or some limited slip diff additive and problem should go away <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: LSD seems to be sticky.? #615219 06/16/05 04:41 PM
powerRam50 Offline
you think that is bad try a spooled rear.
Re: LSD seems to be sticky.? [Re: powerRam50] #615220 06/16/05 05:04 PM
LRJ4x4 Offline
If you have a spool just carry a stray bottle of soap. Even better, reroute your rear washer fluid to the tires. Everytime you turn spray some soapy water on the tires.
Ok, I've filled my dumb idea of the day quota. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: LSD seems to be sticky.? [Re: LRJ4x4] #615221 06/16/05 05:35 PM
powerRam50 Offline
that is funny.but i have gotten used to it and prefer it now compared to open.
Re: LSD seems to be sticky.? [Re: powerRam50] #615222 06/16/05 06:39 PM
used to have spooled rearend in 66 gto street /strip car lots of fun on tight turns <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: LSD seems to be sticky.? [Re: DanWheeler] #615223 06/17/05 02:40 AM
hd77303 Offline OP
Well thanks again for the advise.
I have not changed anything. Only had the new rig a week or so.
I will get new fluid and the additive this weekend.
What are ya'lls recomendations for fluid?
I don't have a problem with OEM but something different might be nice.
If you have to ad the additive what is the recomended amount?
Thanks
KKD
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6184 MB (Peak: 0.7164 MB) Data Comp: Off Server Time: 2026-11-02 04:00:52 UTC
