general alternator question #55773 06/16/03 03:11 AM
tkrispin Offline OP
Hey folks. I was just wondering if the alternators on our toyotas were "self energizing", i.e. if the belt is turning the alt, it is charging (no fuseable links needed so that the alt. sends power to the battery). A mechanic told me that most toyota alternators are. Can anyone confirm this, or know how I would find out?
Thanks...
Tom -|- TLCA #12384 -|- '95 4x4 x-cab mini
Finally E-locked...
1987 Celica GTS liftback - stock for now
...never enough...
Re: general alternator question #55774 06/16/03 03:35 AM
Dandeman Offline
Toyota Moderator
No they are not self energizing... but first, verify your alternator (the back side) looks like the one on page 5 of the document referenced below..
The "IG" lead on the alternator must be supplied 12 volts from the battery (via the ignition switch and fusing) to energize the rotating alternator field winding... then the alternator will provide power back out of the "B" lead to charge the battery..
Go to this link, click on "Technial Articles" and open the pdf file "08 Toyota Charging Systems with questions.pdf" for further information...
In the 3rd Gen (checked schematics for the 2000 4Runner) for example, the fuse labeled "Gauge" is the one that supplies the IG lead.. This may be a different fuse on other generation Toyotas.. If you pull the fuse that is supplying the alternator, it will stop charging.
<small>[ June 15, 2003, 11:06 PM: Message edited by: Dandeman ]</small>
Re: general alternator question #55775 06/16/03 02:53 PM
fourwd1 Offline
Tom, Like Dan said, they aren't self exciting. In fact I don't know of any production car made that uses that method. I had an GM alt converted to use with my V6 conversion to simplify things. One wire alts are usually found on construction equipment like pumps, etc.
Broderick
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: general alternator question #55776 06/17/03 05:23 AM
tkrispin Offline OP
Wow that's a great link! I have a lot of reading to do... Looks like that webpage will get bookmarked too.
Thanks!
Finally E-locked...
...never enough...
Re: general alternator question #55777 06/17/03 12:54 PM
tkrispin Offline OP
Hey Broderick, thanks for the post, I didn't see it right away.
I want to get a tester like the sun VAT-40 mentioned in the webpage above, but they are a little pricey <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> I'll have to shop around for cheap tools and testers...
Finally E-locked...
...never enough...
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6068 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-11-16 01:18:26 UTC
