location of 85 solid axle grease fitting? #615667 06/17/05 04:27 PM
Roland2655 Offline OP
Went in to get my oil changed yesterday and neither I nor the tech could locate where you put the grease. Probably help if I got it steam clean. <img src="/forums/images/graemlins/smile.gif" alt="" />
ridge runner
Re: location of 85 solid axle grease fitting? [Re: Roland2655] #615668 06/17/05 04:40 PM
4Crawler Offline
Well, there really aren't any, at least zerk fittings. You can remove the square headed plus on each side and pump in a little grease if you want. Or you can drill/tap the square plugs to add a fitting:
But most of the time the front axle is lubed by diassembling it:
http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml
Re: location of 85 solid axle grease fitting? [Re: 4Crawler] #615669 06/17/05 05:21 PM
thanks 4 crawler.
ridge runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-06-20 22:46:08 UTC
