Page 3 of 8 1 2 3 4 5 6 7 8
Re: The old Red Chili is dead... [Re: Seldom_Seen] #615690 06/24/05 04:16 PM
Red_Chili Offline OP
Toyota Section Staffer
Thought I would post an update. Took the Chili on a local 3+/4 trail here, Spring Creek. I avoided the first obstacle, its one of the hardest and I didn't feel like almost rolling it possibly should something go wrong.
It was definitely over-cautious. The Chili wheeled better than it ever has, no issues whatsoever. I spent time going up I-70 in 5th, where I would have been in 3rd, and 4th, where I would have been thinking 2nd was not far off. To top it off, the gas gauge moves slower now too.
Another bonus, felt with the front locker engaged: higher power steering pressure. Very light and easy steering. Nice.
Just a couple issues remain, because I wanted to tackle them myself (cheaper). AC hoses: seems like I should be able to cut the four, mate them, and have two hybrids. Maybe splicing in a port on the low and on the high pressure lines. No? But from where do I get these parts?
There is a place local to me, Maxair, who will no doubt do a fantastic job of hoses, a new condenser (do I really need one for R134a???), and a charge, for keeping my truck a couple days <img src="/forums/images/graemlins/angry.gif" alt="" /> and relieving me of $350. <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
I think I'd go with onboard air first. But on those hot days...
Secondly, there are lots of articles on making 3.0 tachs work, simple job really. If only I had one. Has ANYone made the 4 cylinder tach work with a resistor here and a mod there? Or is it a whole different animal, and do I have to locate an 88 or 89 3.0 tach somewhere (getting rare...)?
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615691 06/24/05 07:40 PM
FattyCBR Offline
Re: Tach
Do you know where the tach reads it's signal from on your stock 22re (on my 98 it reads it from the ECU, which has a tach wire)? They may utilize different signals since the 22re used a distributor and the 3.4 is DIS. That doesn't answer your question, but the new signal may not be compatible with your old tach.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: The old Red Chili is dead... [Re: FattyCBR] #615692 06/24/05 08:54 PM
Yes, but both are equally true with the 22RE and the 3.0 tach. Yet the 3.0 works with a 10Kohm resistor. My question is, how does the 4 cylinder tach differ from the 3.0, and is it possible to make it work via similar hacks?
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615693 06/24/05 09:30 PM
bwhitehead Offline
Hey Bill tach are different. I just did one last year I converter an 86 22RET truck over to a 3.4 and also the digital dash over to a SR5 dash that I believe was a 4cylinder and the 10kohm resistor mod worked. I will see if I took any picts and if I didn't I will try and get some for you.
Brandon
93 4Runner 3.4 swap, SAS, 37 Mtr, 5speed swap, High pinion ARB Front an Arb rear, ARB air compressor, Marlins Dual cases, bud built crossmemeber, 63 leaf spring swap. Sky rear disc conversion and the money keeps flowing!
Re: The old Red Chili is dead... [Re: bwhitehead] #615694 06/24/05 10:07 PM
Ah, hi stranger! Bearing welcome gifts too, I might add. COOL! Same location as the 3.0 mod then? Surely, not the same 10Kohm, no? If it really was a 4 cylinder cluster, it would not have the telltale '6' on the tach face below the bezel IIRC.
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615695 06/24/05 10:53 PM
bkg Offline
If the tach input signals are the same between a 4 and 6-cyl tack, you might be able to make it work. I used a 10K adjustable pot on a 4-cyl tach to work with the 4.3 per Jay K's instructions. But if you need a 10K for the 3.0 tach, will that be enough for the 4-cyl tack, or will you need more? Ugh. Soo many questions...
Brian K. Gallus
Re: The old Red Chili is dead... [Re: bkg] #615696 06/24/05 11:11 PM
Knowing that you did the 10K mod on an I-4 tach for a chebbie V6 and it worked... and that maybe it worked with another 3.4... emboldens me to try maybe a 30K or even a 50K trim pot preset at 10K, mounted where I can get at it, and give it a go. That should cover things. Thanks, guys!
I suppose it's working as a pull-up resistor maybe? I can see from the schematic that the 22RE ignitor is acting as a grounding input in the stock setup, with the other side of the tach on the +12 rail. Wish I had a schematic of the tach itself, it would answer so many questions.
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615697 06/25/05 12:17 AM
Jeepeater Offline
In the interest of preserving bank accounts of everyone reading, I respectfully request that this thread be deleted.
Thanks a lot, Bill. I thought I was already broke enough as it is, now I have to figure out how to swing this mod too. <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: The old Red Chili is dead... [Re: Red_Chili] #615698 06/25/05 12:45 AM
bkg Offline
Uh... yeah.. er... sure, Bill... That's what I was thinking, of couruse... <img src="/forums/images/graemlins/drunk.gif" alt="" />
electrical stuff makes no sense to me...
Brian K. Gallus
Re: The old Red Chili is dead... [Re: Jeepeater] #615699 06/27/05 04:55 PM
I know... I have the disease too...
-Bill
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6481 MB (Peak: 0.7746 MB) Data Comp: Off Server Time: 2026-05-30 02:25:05 UTC
