Rear-ended! #617062 06/21/05 02:05 AM
Mavranos Offline OP
Some lady was busy yappin' on her phone and slappin' her kid in back seat and slammed into me at a traffic light. My 1989 4runner is looking sad. Got an insurace settlement. Now I've gotta find a tailgate. My local scrapyard want 650 for one they have. I'm hoping to find one cheaper so I can afford to buy some new toys.
Any sources you guys could recommend would be appreciated!
Any hints on saving the glass which is intact and up but I dont see how I can get it out of the smashed tailgate without breaking it. I would like to save it -
Thanks
Re: Rear-ended! [Re: Mavranos] #617063 06/21/05 02:29 AM
4Crawler Offline
Ouch!
For parts, try http://www.car-part.com/ to search nearby junkyards (not sure where you are located, might want to fill out your user profile).
For removing the glass, maybe a SawZall or other metal cutting device to remove the back of the tailgate to gain access to the inner parts. Not sure if you can get to everything through the access panel inside or not.
Re: Rear-ended! [Re: 4Crawler] #617064 06/21/05 08:14 AM
mudking82 Offline
Just cut a big hole in the tailgate, both sides if necessary, to be able to access all the components so you can unbolt your window. Sawzall will work fine, just make sure you use a short blade so you don't jab it into anything on the inside of the door. But for less vibration use a high speed cutter that runs off an air compressor(if you have one). They usually use a 3" cutting disc that turns at like 20,000 RPM, and they work good. Or an air powered sheet metal nibbler will work even better once you get a hole started. I used both of these to cut open the outside of my doors on my car after it was hit in the side to do the same thing-save the glass.
Re: Rear-ended! [Re: mudking82] #617065 06/21/05 03:11 PM
You can get a brand new (pre-primed) tailgate on ebay for $100 shipping included......
Here is one for an example:
http://cgi.ebay.com/ebaymotors/ws/e...p;item=7982045549&category=33640
Re: Rear-ended! [Re: Mavranos] #617066 06/21/05 04:01 PM
ZUK Offline
Thanks
hahaha....you could have used a rear bumper like mine <img src="/forums/images/graemlins/cyclops.gif" alt="" />
mostly stock
Re: Rear-ended! #617067 06/21/05 06:58 PM
Toy Story Offline
That's a pickup tailgate. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
85 Toyota SR5 Xtra Cab P/U
Re: Rear-ended! [Re: Toy Story] #617068 06/21/05 07:12 PM
Re: Rear-ended! #617069 06/21/05 07:39 PM
anthony1 Offline
I think this is what he's looking for...
http://cgi.ebay.com/ebaymotors/ws/e...647&item=7981572482&rd=1
Here's one with zero bid..99 cents...It's in New Jersey. Pick up only. Might be worth the road trip. Even with gas at 2 bucks a gal. if you get 20mpg, you're only looking at less than 150 worth of gas...I think.
http://cgi.ebay.com/ebaymotors/ws/e...647&item=7981403369&rd=1
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Rear-ended! [Re: Mavranos] #617070 06/21/05 08:33 PM
Esquire812 Offline
Talk to CJM about a fiberglass replacement. Will cost you alot less than what you have been quoted so far. I paid like $70 for the used replacement for my 87'and it came with regulator but no glass. I had new glass anyways...different story. Keep in mind that your used tailgates will have some blemishes and dont be afraid of getting one that is a different color. Painting to match is cheap. I gave my old one away to Cisco for him to butcher and use on his trailrig.
For pulling the glass from your existing mangled metal, pull the inside cover, raise the window to halfway point (tailgate down btw-part of that story I was mentioning <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) unbolt the regulator and slide the arms off the channels at the bottom of the glass. Window will slide out easily. No reason to hack anything. Besides, you are going to want to transfer the lock cylinder, window switch over to the new tailgate anyways...unless you are lucky enough to find one complete with key.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Rear-ended! [Re: Esquire812] #617071 06/22/05 06:06 AM
mudking82 Offline
Guess I should of added to only start hacking away at stuff IF your tailgate is so mangled that you can't get stuff to come apart the proper way(as my doors on my car were). Definitly much easier if you can just unbolt it all as Darin said.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6401 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-06-17 01:54:10 UTC
