Rear spring perch width #620098 06/27/05 11:23 PM
carter Offline OP
When did Toyota start using wider spring perches on the rear IFS axles? I know about the difference between '85 and '86, but sometime after '86 they went even wider.
I'm trying to swap in a rear axle from the 90's and the u-bolts won't fit because the perches are wider than the holes in the mounting plates. <img src="/forums/images/graemlins/zombie.gif" alt="" /> So I need to look for new mounting plates and want to know what years to look for.
No, I don't want to do a u-bolt flip if I can help it as this is on my daily driver and I don't want to have to screw around with changing shock mounts, etc.
Mike Carter
85 & 86 4Runners
My Website
Re: Rear spring perch width [Re: carter] #620099 06/28/05 05:50 PM
ErikB Offline
Toyota Moderator
Its only some of the 90's trucks, not all. I think RogerB has some info on those... ?
http://home.4x4wire.com/erik
Re: Rear spring perch width [Re: ErikB] #620100 06/28/05 06:16 PM
4Crawler Offline
Yep, some of the 3rd gen pickups ('89 or later) had the wider perch and the rubber lined clamp to hold the springs. One option is to grind notches into the sides of the wide perch to fit the narrower u-bolts and spring plate, or cut off the wide perch and weld on a narrow one, or get a set of wider bolts and plates.
Re: Rear spring perch width [Re: 4Crawler] #620101 06/28/05 06:50 PM
carter Offline OP
Thanks for the information and suggestions. So Toyota had both styles in the 90's? Weird.
Mike Carter
85 & 86 4Runners
My Website
Re: Rear spring perch width [Re: carter] #620102 06/28/05 07:00 PM
Brian894X4 Offline
My '89 single cab short bed truck came with the wider perch.
Re: Rear spring perch width [Re: 4Crawler] #620103 07/09/05 06:06 PM
carter Offline OP
I looked at grinding notches in the perches to fit the narrower ubolts, but it would have comprimised the end bracing of the perch and I would have had to fab up new bracing.
This is my dd and I really don't feel like spending time messing around with it, so I am still looking for a set of spring plates.
Someone must have a set of these lying around after a ubolt flip... Buller???
Mike Carter
85 & 86 4Runners
My Website
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6086 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-07-10 01:24:56 UTC
