Upgraded Tie Rod Ends #620155 06/28/05 01:28 AM
JWHnAtl Offline OP
I saw this thread on the Isuzu forum: Stinkyfab Tie Rod Ends - prototype
I e-mailed him about their use or adaptation for Toyotas:
TRE's would have to be different because of the taper, and I'm positive the length would be different as well
I'm sure a setup could be made for toys with a similar design, but they would be entirely their own parts.
He wanted 10 guinea pigs, er, I meant bold, adventurous types to make a production run for Isuzus. Is there any interest here to get some of these?
Any interest in upgraded tie rod ends?
single choice
Votes accepted starting: 06/27/05 05:00 AM
You must vote before you can view the results of this poll.
'89 3.0 4Rnr: Jacob's Electronics, K&N, CF Dual Frict, 4:56 w/ Truetracs, 33 BFG AT/KOs, Cascade Audio, Pro-Comp 4" susp & 2" body (previous owner)
I know, a lot of wasted time and money ... if I knew then what I know now....
Re: Upgraded Tie Rod Ends [Re: JWHnAtl] #620156 06/28/05 02:15 AM
OOP'S Offline
Why not talk to Marlin or SKY and have them make up some short tie-rods with FJ TRE's. I am pretty sure they will work in your steer arms.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Upgraded Tie Rod Ends [Re: OOP'S] #620157 06/28/05 03:02 AM
kyle-22r Offline
why not build them with FJ80 ends?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Upgraded Tie Rod Ends [Re: kyle-22r] #620158 06/28/05 04:01 AM
JWHnAtl Offline OP
I've written a couple of places who pretty much just replied that their products wouldn't work to upgrade mine. It's been a while and I don't remember which companies I wrote to, but I gave up on using the FJ ends.
Re: Upgraded Tie Rod Ends [Re: JWHnAtl] #620159 06/28/05 05:49 AM
ldivinag Offline
has anyone had a tierod failure?
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Upgraded Tie Rod Ends [Re: JWHnAtl] #620160 06/29/05 08:37 AM
Snowtoy Offline
Look into 1 ton toyota steering linkages. I have not verified it, but i was told that the 1 ton stuff is bigger. I figure if mine ever fail, I would look into 1 ton stuff.
You could see what a machine shop would charge to machine down a larger end and cut new threads, shouldn't be that much.
Re: Upgraded Tie Rod Ends [Re: ldivinag] #620161 06/29/05 08:48 AM
kewlynx Offline
Yes, and THANK GOD they failed while turning, under 20 mph, or I would've rolled the truck. I did this not once, but twice. I had the 2nd set of tie rod ends sitting in the floorboard; about 3 days apart.
Inners failed on both of them. Pop your outer one loose sometime and see what your wheels do. It's something you DON'T want happening at highway speed. The first one took me straight off the road about 30 feet; luckily no ditch. The second one I managed to get off the road; changed that b*** right there; still had the pickle fork behind the seat.
You'll notice I had the parts for the other side; if you change one, change 'em both, cuz chances are the mate isn't far behind the first one.
That was at 320K, IIRC.
**ubi apis- ibi salus**
Re: Upgraded Tie Rod Ends [Re: kewlynx] #620162 06/29/05 12:20 PM
Brian894X4 Offline
Wow! I think that has to be highly unusal. Considering the number of guys that run taller than stock tires on trucks with hundreds of thousands of miles with the stock tie rods and no problems. Worst case I've heard is bent tie rods from reefing on the steering wheel after a tire got wedged in between rocks.
Were these the tie rod ends themselves that snapped off or the rods? And were they factory or aftermarket? I wonder if the extreme cold of Alaska could have some unforseen affect on them. Of course 320K miles and if that was all in Alaska....
Man, I'm sure glad you didn't get hurt!
Re: Upgraded Tie Rod Ends [Re: Brian894X4] #620163 06/29/05 12:52 PM
SHAD Offline
I bent 2 tierods and about 3 idle arms when I was running ball joint spacers on my 93 4 runner.
It all depends how the terrain is and how slow you go over it. Add alot of addtional weight to your truck rock sliders, bumpers, TRE's bend easily.
I don't have that problem anymore though I have a SAS truck <img src="/forums/images/graemlins/smile.gif" alt="" />
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Upgraded Tie Rod Ends [Re: SHAD] #620164 06/29/05 02:13 PM
JWHnAtl Offline OP
I've always wondered about the angle of the TREs with my lift. Now, I've added the ball joint spacers and was just thinking of upgrading, if possible. I've read that many people have trail spares. Instead of buying a spare, I would rather upgrade them and keep the stocks ones as a trail spare.
PHP: 7.4.33 Page Time: 0.009s Queries: 19 (0.006s) Memory: 0.6588 MB (Peak: 0.8294 MB) Data Comp: Off Server Time: 2026-06-09 23:19:17 UTC
