rear diff interchange #620550 06/29/05 01:10 AM
DMYERSCHATTTN Offline OP
I have a 1989 Raider with a 2.6/auto, with LSD in the rear. Instead of repairing the engine, I've found a 1986 SWB Montero, with a 2.6/5 spd, open gears. Can the LSD chunk from the '89 be installed into the '86, or is there any difference in axles, gear ratio, etc.? The '86 will cost about the same as the necessary repairs on the '89, but it has new 33's, a roll bar, and a gold tone paint job that I prefer over the red on the raider. I can keep the raider for parts.
90 MONTERO ... Beat, Banged, 4DR recovery and recon vehicle... just keeps going and going...
Re: rear diff interchange [Re: DMYERSCHATTTN] #620551 06/29/05 01:28 AM
NathanC Offline
Since they are both 2.6's the diffs should swap just fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: rear diff interchange [Re: NathanC] #620552 06/29/05 05:23 PM
powerRam50 Offline
are you sure the 86 dont have a lsd?
Re: rear diff interchange [Re: powerRam50] #620553 06/30/05 02:50 PM
The Raider (89) has a warning sticker in the driver side door pillar, along with a modification label. I did not see those on the '86 Monty. Although I've jacked two Raiders with labels (which have LSD), and a few of both Raiders and Monties without (labels or LSD); they were all in the '87-'90 range. I'ts worth the three minutes to check a non-labeled truck anyway, 'cause you never know. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Limited Slip Sticker
Re: rear diff interchange [Re: DMYERSCHATTTN] #620554 06/30/05 05:10 PM
L
Lester Offline
The entire axle can swap over without any problem. Save the hassle of removing the LSD assy. Check once again the 86 with one rear wheel up. There should be resistence in turning the free wheel. otherwise, you really got an open!
Re: rear diff interchange [Re: Lester] #620555 07/01/05 05:22 PM
The '86 is definitely open. The man is asking $1500 for it, after changing the engine. The engine smokes, so I can see why the customer did not want to pay the bill for it.
Re: rear diff interchange [Re: DMYERSCHATTTN] #620556 07/01/05 05:28 PM
here it is, if anyone else is interested in it. '86 Montero, Chattanooga TN
Re: rear diff interchange [Re: Lester] #620557 07/02/05 04:38 PM
BobShaw Offline
You don't need to swap the entire axle, just the 3rd member.
Bob Shaw
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6222 MB (Peak: 0.7046 MB) Data Comp: Off Server Time: 2026-11-02 15:16:29 UTC
