Fluid Type #621399 07/01/05 07:29 PM
javven Offline OP
Does the x-fer case in my 88 use 90wt? 5sp 4cyl.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Fluid Type [Re: javven] #621400 07/01/05 07:58 PM
Mississippi_Blue Offline
From my 88 Owners Manual - Transfer Case - 2.2 liter (2.3 qts) - API classification GL-4 or higher SAE 75W-85W, 80W Mopar Hypoid Gear Oil or equivalent.
'87 RAIDER, rebuilt & modified, "Bleaux"
'87/'88 Mitsu Montero SWB, parts truck.
'03 Mitsu Montero Sport ES - my "driving Mz Daisy" station wagon.
Re: Fluid Type [Re: Mississippi_Blue] #621401 07/01/05 08:29 PM
javven Offline OP
TYVM sir, you're a gentleman and a scholar.
Re: Fluid Type [Re: javven] #621402 07/01/05 08:50 PM
Female - <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Fluid Type [Re: Mississippi_Blue] #621403 07/01/05 08:56 PM
javven Offline OP
Open mouth, insert foot. Mmmm.... tasty toes.
Thanks just the same, no offense intended.
Re: Fluid Type [Re: javven] #621404 07/01/05 09:07 PM
That's okay. I'm really glad I helped someone for a change. I'm new and have been asking question after question. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Fluid Type [Re: Mississippi_Blue] #621405 07/01/05 09:16 PM
javven Offline OP
I just got caught without my:
Electronic manual.
Shop books.
Aftermarket books.
Quick Reference Sheet.
The end total for the work I just had done was $737. Not too bad. Clutch replacement, a few other things. Nothing wrong now that will require de-mating the tranny later on, so that's a good place to start.
Thx for the help. Stick up for yourself - you're a pretty good person from what I've seen so far. You'll find you're very welcome on this board. If someone seems odd to you, just remember - we're all here because we're not all there....
Re: Fluid Type [Re: javven] #621406 07/02/05 02:24 PM
52degrees Offline
I run GL-5 in my transfer case. No problems so far.
The 5-speed tranny is a different story. GL-5 is not acceptable for use in the transmission.
I'm using Redline MTL there. It also works in the transfer case, but I haven't put it in yet.
Clay
KG6VNX
Re: Fluid Type [Re: 52degrees] #621407 07/03/05 07:16 AM
javven Offline OP
Mobil1 85wt in both here.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6257 MB (Peak: 0.7122 MB) Data Comp: Off Server Time: 2026-05-29 23:53:46 UTC
