high pinion 5.29 r&p backorder? #622823 07/04/05 10:07 PM
CraShYota Offline OP
are the 4.88 and 5.29 high pinion gears still on backorder?
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: high pinion 5.29 r&p backorder? [Re: CraShYota] #622824 07/05/05 01:40 AM
from randys and driveline they are. I called them last week to find out about the 4.88s front and rear and that is what they said. I think it was randy though that said they had an assembled rear high pinion third with a detroit with 4.88s in stock. I don't need another third though. Not including the one in my truck right now I have two sitting in my garage right now.
Re: high pinion 5.29 r&p backorder? #622825 07/05/05 02:01 AM
OOP'S Offline
There is no such thing as a "rear high pinion" for a Toyota 8"!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: high pinion 5.29 r&p backorder? [Re: OOP'S] #622826 07/05/05 10:32 PM
[/quote]There is no such thing as a "rear high pinion" for a Toyota 8"!!!!! [/quote]
Yes there are. Here is a Marlin one. high pinion for 8"
Re: high pinion 5.29 r&p backorder? #622827 07/05/05 11:53 PM
OOP'S Offline
I dd not say they did not make one, I said they do not make one for the REAR. Try and run one in the rear of your Toyota, I guarantee you will blow it up. Especially if it is a DD. Marlin has tried a few times. I run one in the front. They come out of the front of a LandCruser and the gears will not take running on the coast side of the gears in the rear. If they worked in the rear me and hundreds rockcrawlers would have them. I would go and buy one right now!
David Fritzsche
Roseville, CA
Re: high pinion 5.29 r&p backorder? [Re: CraShYota] #622828 07/06/05 12:08 AM
redtoy92 Offline
e
2003 TRD EXT.CAB V-6 SR5
supercharger+urd fuel mods
6inch fabtech+1RB
35 BFG MT 4.88's Stubbs sliders
Re: high pinion 5.29 r&p backorder? [Re: redtoy92] #622829 07/06/05 02:32 AM
this doesnt solve me issue of the gears being on backorder... whyyy? and why for the past like... 3 months. or where can i get a high pinion diff with 5.29 gears and an arb locker?
Re: high pinion 5.29 r&p backorder? [Re: CraShYota] #622830 07/06/05 03:44 AM
OOP'S Offline
Try Inchworm.
http://www.inchwormgear.com/
David Fritzsche
Roseville, CA
Re: high pinion 5.29 r&p backorder? [Re: OOP'S] #622831 07/06/05 03:51 AM
Oh I believe you and I agree 100% with what you say. When I had talked to one of their salesmen a couple of months ago he was telling me that they do have a rear high pinion third. Maybe I misunderstood him, but I don't think so. Sorry for not being clearer before.
Re: high pinion 5.29 r&p backorder? #622832 07/06/05 04:38 PM
talked to marlin he said that they have been on backorder for 6 months and the list for one is longer then... yuh so i decided to get a v6 third with detroit and 5.29 and throw it in my rear and put the 4cyl with lockright lunchboxer in the front again. now i just need to get a driveshaft from highangledriveline.com
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6323 MB (Peak: 0.7564 MB) Data Comp: Off Server Time: 2026-06-18 13:14:03 UTC
