Alternator questions
#623553
07/06/05 06:57 PM
I just bought a 400W inverter and it got me thinking about power options down the road. Here's a few questions:
1) Is there a rebuild kit for the alternator? My pre-taco alternator died around 150k miles and I have 130K on the T. Thinking about rebuilding before it goes. 2) Is there a high output alternator available for the T? I believe the stock alternator puts out 50-75A. 3) Thinking about installing a larger battery with deep cycle capability. Has anyone done this and are there any hints/pictures?
I have a 3.4L '97 4x4 with an automatic. I plan on putting a cigarette lighter outlet in the bed and in the cab that doesn't shut down with the ignition and a setup for the inverter in the bed close to one of my cap windows.
Thanks!
97 T100 4x4 SR5 Extra cab Automatic 3.4L engine
Re: Alternator questions
[Re: Shedman]
#623554
07/06/05 08:09 PM
Let's see...
1. - I imagine there probably is, but I'm not 100% sure...
2. - Yes... Stock output is 65-85amps - too weak IMO. Take a look on Ebay - you can usually find the 110-130amp units for the 5vzfe. Also, if you want the max power & don't mind spending some coin you can take a look at NWOR's 160amp unit (I'm happy with it, but it was close to $500) or PowerMaster (alternators associated with their welding equipment).
3. - Optima... I run the blue top deep cycle (just 'cause I wanted the extra set of posts). Only thing is I had to make some slack in the positive lead (cut a couple zip ties to loosen it up) & bend the top support bracket down about .5" (the Optima's are shorter than OEM). Nothing to it. I can take a couple pics for you if want - PM me an email addy...
Good idea for the inverter, but is 400w enough? What do you plan on running on it? May want to think about returning it & getting a bigger one if you want to run a blender/hairdryer size item. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
[Re: Shedman]
#623555
07/06/05 10:44 PM
The only thing bad about the inverters is that they put out a lot of radiated noise, esp. in the entertainment radio bands. Really screws up the AM and the FM to a lesser degree. Also depends how close to the antenna it is and how much gets radiated off the power cables up to it. Just an FYI.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: garym]
#623556
07/07/05 12:17 AM
I suppose the key is to turn it off when you don't need it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: 4xGeek]
#623557
07/07/05 09:59 PM
I'll look around for the 135A unit on E-bay. Didn't know they sold such an animal. I think the $500 ones are a little much for what I need.
I have a remote piece of property with no electricity and just need to power a few small items. I would also like to power a small fan for cooling the dog in the summer. The D-cell battery fans are junk. I plan on running some heavy wire (with a fuse at the battery) to the bed and making a sort of power panel. That way I could use the inverter off of a cigarette lighter socket for small things or direct for larger items. If I upgrade to a larger inverter I have the wiring done already.
Thanks for the suggestions. Still haven't found a rebuild kit in my searches.
[Re: Shedman]
#623558
07/09/05 04:20 AM
I have a 1000watt inverter under the seat and could use a new alternator also. Although so far I have not had any problems with the stock one. Mostly run a microwave or some power tools if needed. I have a procomp yellowtop with top and side posts. I lloked at the series 31 optima but I think its too tall to fit. Depends on if the measurments they give are to the top of the battery or the top of the posts
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc. 99 F-350 4x4 superduty supercab turbodiesel longbed
