88 XJ leaking #623966 07/07/05 03:16 PM
RSimister Offline OP
Does anyone know where I can find a write up on changing out the rear seal on my XJ? What was a minor drip is now going to eat my driveway.Its a 4.0 and should be a two piece seal so maybe the trans wont have to come out
Re: 88 XJ leaking [Re: RSimister] #623967 07/07/05 03:42 PM
BigJim Offline
I think ou are asking about changing the rear mail engine seal.. If so the first thig to do is check all of the BREATHING hoses on top of the engine and the PVC valve. If any of these is not operating correctly you will build up pressure in the engine and the first place it comes out (with oil) is the rear main seal.
Now that said.. to give you a hint of just where it is. When Mopar builds an XJ the first thing they do is to place a rear main seal on the start of the assembly line! Then as the line moves an XJ is built around that damn seal!
Re: 88 XJ leaking [Re: BigJim] #623968 07/08/05 03:06 AM
My chilton had all the directions to do it. The key is to make sure that there is 100% no oil when you add the RTV on the bearing caps. It also helps a lot if you remove all the bearing caps and support the crank with a jack stand.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5887 MB (Peak: 0.6435 MB) Data Comp: Off Server Time: 2026-06-09 21:53:11 UTC
