PCV Valve.... Where is it located.on the V6 3.0? #624588 07/08/05 09:44 PM
W
WashingtonKevin Offline OP
It is running rough and I am swapping out the fuel filter and plugs this evening. I want to check and clean the pcv valve if I can find it?
Thanks in advance,
Kevin
... who just rebuilt me rearend and dropped in a true-trac. all good.
Re: PCV Valve.... Where is it located.on the V6 3.0? [Re: WashingtonKevin] #624589 07/08/05 09:59 PM
1
1FastSS Offline
Passenger side about mid-way on the valve cover(under the intake). You will need a long pair of needle nose plyers. I purchased a new hose as well as my hose was brittle and fell to pieces when I took it off. The hardest part is getting the grommet back in with the PCV valve(you will need a new one of these also, since it will be hard as a rock). Put a little greese on the PCV valve and it should go......It's a pain and takes some time.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: PCV Valve.... Where is it located.on the V6 3.0? [Re: WashingtonKevin] #624590 07/09/05 01:39 AM
kewlynx Offline
Hi Kevin, we also have a 93 FSM sticky'd here for reference; includes 22RE and 3.0 information. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5907 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-10-24 03:07:50 UTC
