W56 Tranny ??? #625880 07/12/05 09:57 PM
Monty n Guate Offline OP
Hello All,
Here is an interesting conundrum for you. My transmission was supposedly rebuilt last year here in Guatemala. However in the last 8 months I?ve had it go out on my 3 times. Each time it is the same problem. When I shift into reverse the shifter goes to far and then jams up leaving the transmission in 4th gear. Each time that this has happened has been in ¿normal circumstances¿. Not high torque or uphill or anything in which the extra force could be explained. The mechanic cannot find anything in the tranny that is wrong. However obviously there is a problem. Has anyone had this problem or know what part(s) is required to fix it. I don?t want this to happen to me on the trail some day.
Thanks for your help. <img src="/forums/images/graemlins/confused.gif" alt="" />
Don Iler
97 4cyl. Tacoma
OME 881s, N91s, Alcan AALs, Rancho 9k rear shocks
4.56 gears
32x11.50 Procomp ATs
Re: W56 Tranny ??? [Re: Monty n Guate] #625881 07/13/05 05:31 PM
Red_Chili Offline
Toyota Section Staffer
Most likely, I would guess the mechanic left out a limit clip, or keeps reusing used ones that have lost their springiness, and/or left out one or more of the interlock pins. Refer to the R151 article in the tech section for an example of what happens and see if it matches your symptoms.
It's not hard to do it yourself, by the way...
-Bill
Re: W56 Tranny ??? [Re: Red_Chili] #625882 07/14/05 01:36 AM
matts Offline
I hope it's true. I'd like to try my hand at a tranny rebuild on a G52. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: W56 Tranny ??? [Re: matts] #625883 07/14/05 03:39 PM
Red_Chili Offline
Marlin upgrades these, and it may involve re-machining the case to accept larger bearings IIRC. Might be worth considering, as the G52 was not, um, exactly Toyota-class robust.
-Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6037 MB (Peak: 0.6601 MB) Data Comp: Off Server Time: 2026-06-21 09:58:43 UTC
