ABS Sensor on '00 Rodeo
#625909
07/13/05 12:31 AM
Okay, I asked a question about my serpentine belt and got exactly the help I needed, Thanks.
Now I have a question about the ABS sensor on a '00 V6 Rodeo. The sensor light keeps going on and off and the brakes feel just fine. The dealer said it's probably just the sensor as they tend to be problematic. My question is does anyone know where the sensor is located on this model? Figure it can't be too hard to replace, if I can just find it.
Re: ABS Sensor on '00 Rodeo
[Re: 00328]
#625910
07/13/05 01:00 AM
You either have 3 or 4 ABS sensors. My 98 has two at the front, one on the back side of each rotor, you'll see a wire going to it. Then one on the back in the top middle of the diff but for a 2000 it may have one sensor at each rear wheel instead of in the diff.
[Re: ProBMXer1313]
#625911
07/13/05 03:55 AM
Well damn, that kind of complicates things a little.
[Re: 00328]
#625912
07/13/05 05:02 AM
Get the code pulled. It should tell you which one it is.
[Re: 00328]
#625913
07/13/05 12:33 PM
This might work on 2000 models. Here's a link to the Diagnostic Truoble Codes (DTC) you can access with out a scanner. For my 99 Rodeo the standard OBD II scanner couldn't read the ABS codes. You have to have the factory scan tool. ABS DTC Document
If you want something done right do it yourself two or three times! LetsRodeo1999 Isuzu Rodeo LS 4WD 3" CPL, 3" BL LT265/75 16 TOYO Open Country AT ShrockWorks Rock Sliders
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6718 MB) Data Comp: Off Server Time: 2026-05-29 17:12:32 UTCValid HTML 5 and Valid CSS
