Leaky Diff #56846 06/23/03 09:36 PM
Terry4X4 Offline OP
Weekend before last I scrubbed the rear diff a couple of times on the Rubicon and eventually tore out the rear diff plug. I borrowed a spare and qt of gear oil and was back on the trail. Since then the diff had been dripping on the driveway at home. Last week I picked up a new plug and yesterday went to put it in. The threads on the borrowed plug got hosed pretty good. I gently put my finger in the hole and felt the threads and they were pretty hosed as well from the plug being ripped out. I raced to the hardware store before they closed and got a tap to redo the threads. After tapping the threads, the new plug went in normally and appeared to seat properly. However, now it is leaking worse than previously.
I thought about using some RTV around the plug to seal it up. However, thinking about removing it in the future seems like it will be a PITA. Any other suggestions to stop the leaky rear diff?
Terry Johnson
Gettin' Off 4X4 Club
'89 XCab SR5 V6 - D60 Hybrid SAS, Ultimate Marlin Crawler, Detroit rear, ARB front
'97 TJ - Atlas 3.8 Twin Stick, ARB F&R, custom rollcage
Re: Leaky Diff #56847 06/23/03 09:50 PM
DirtyHarry Offline
Toyota Moderator
Well you could get one of Roger's plates and shave the bottom of the diff, that would take care of the problem. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Short of that, I don't see why using RTV would be a problem, other than the fact that you will have to drain the diff again and clean it will before applying the silicone.
Re: Leaky Diff #56848 06/23/03 10:41 PM
4Crawler Offline
Here's another option that I used to run on my axles:
Diff plug fix
Re: Leaky Diff #56849 06/23/03 10:51 PM
Weld that sucker!! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Leaky Diff #56850 06/23/03 11:00 PM
little_joe Offline
Former Admin
Use Hylomar from Permatex on the threads. If it can stop the leaks on my Rover, Toyota leaks should be no problem. It's real easy to work with and the plug can be removed/installed w/o having to redo it each time.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Leaky Diff #56851 06/23/03 11:05 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Leonel Quinteros:
<strong>Weld that sucker!! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Worked for me <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Leaky Diff #56852 06/23/03 11:39 PM
Terry4X4 Offline OP
Thanks guys. I'm aware of the welded plug option, I just don't want to go there yet if I don't have to. <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
Terry Johnson
Re: Leaky Diff #56853 06/24/03 01:29 AM
4Crawler Offline
Might be able to find an oversize plug and have the hole drilled and tapped for that. Looks like 3/4" or a 1/2" NPT thread would be a bit larger than the existing 18mm size.
Re: Leaky Diff #56854 06/24/03 03:36 AM
Do what I did:
<img src="http://www.yankeetoys.org/KLF/Taz2/AxleShave/RearShave3.jpg" alt=" - " />
Re: Leaky Diff #56855 06/25/03 11:55 PM
I resisted it too, but after loosing the front and almost loosing the rear (both low profile hex plugs) at the Hammers last spring I welded mine. It is really not that hard to drain through the studs and then you never need to worry about it again. Simple, free and done.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6323 MB (Peak: 0.7545 MB) Data Comp: Off Server Time: 2026-11-19 05:20:18 UTC
