Front Turn Signals Dont Work #627338 07/16/05 04:05 PM
Ride Hard Offline OP
For some reason, starting yesterday, my front turn signals do not work anymore...
If push the lever to turn left, the rear left blinker will come on, but the front 2 (below headlight, and sidemarker) do nothing. If I push it to turn right, the amber light below the headlight will come on, and barely blink (not like its supposed to), and the side marker does nothing. But the rear still works fine.
Then, if I turn on my parking lights/headlights, they all work fine. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I have replaced all the bulbs, and still have this problem. What else should I be looking for? <img src="/forums/images/graemlins/confused.gif" alt="" />
Its a 93 3.2 automatic rodeo...
'93 Rodeo - Dana 60 FF Rear - Dana 44 Front - 35's
Re: Front Turn Signals Dont Work [Re: Ride Hard] #627339 07/16/05 04:32 PM
Canucklehead Offline
Until I look at the schematic I can't really give you any input regarding you front turn signals not working properly, but I can tell that the side marker lights are not supposed to flash with the turn signals or hazard flashers. They only come on when you turn on the parking lights or headlights.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Front Turn Signals Dont Work [Re: Canucklehead] #627340 07/17/05 03:33 AM
JLEMOND Offline
DOES your truck have a trailer hitch , if so check the light adapter in the rear , it is quite common for the diodes in these things to short out and they will cause some weird things with the turn signals , you should be able to just unplug the harness assuming you have one right in the middle of the rear bumper on the under side should be the plug also check the wire harness ground at this point , common prob there also Jerry
Re: Front Turn Signals Dont Work [Re: JLEMOND] #627341 07/17/05 04:47 AM
Thanks alot, i just went and looked at the trailer harness.
There was a few wires that had gotten rubbed open/cut completly on the trailer stuff, somebody did a really bad job of hooking it up...
I also had a bad ground on one of my front lights... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Thanks alot
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6020 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-11-17 11:03:06 UTC
