IFS Swap #627574 07/17/05 03:54 PM
Kaptain Offline OP
Im Taking off all of the ADD junk on the Carrier I just picked up.. Little confused by the FSM sticky were have here.. In the dissasembly pic it shows a snap ring on both shafts, however in the removal of each of these they are either pulled out or tapped out. It says nothing about removing these clips (I have the diff cover off and i can't even see these snap rings)
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: IFS Swap [Re: Kaptain] #627575 07/17/05 06:18 PM
Kaptain Offline OP
Okay, i got it... Tapped the driver side shaft out easily with a hammer, and pulled the other side with a dent puller <img src="/forums/images/graemlins/kewl.gif" alt="" /> (Fabbed a piece of steel that was bolted to two sides of the flange and hole in the center for the puller) Worked out very well.
93' Toy xCab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5894 MB (Peak: 0.6373 MB) Data Comp: Off Server Time: 2026-06-07 11:33:06 UTC
