Bent Wrangler YJ frame #627638 07/18/05 01:56 AM
95 Wrangler YJ took on a light post. Bumper and tube behind it bent in a "V". Grill and hood damaged. Ends of frame ahead of front cross member are bent in. Can these be cut off and new ends (with tube) welded on? If so, where can i find them? Or do I need to take the jeep to a frame shop and have the ends straightened?
Thanks
Mike B
Re: Bent Wrangler YJ frame #627639 07/18/05 02:36 AM
The frame shop is your best bet, more than likely the frame is bent in more than that place.
Re: Bent Wrangler YJ frame #627640 07/18/05 03:17 PM
NCBBA2358 Offline
I'd have to agree with Sunder on this one.
Take it to a frame shop, have them pop your body loose and tweak your frame to factory measurements.
My 91 had front and rear collisions in it's life, one each were really bad. Each times, I had a regular shop do everything they could to get the body to look like it hadn't been wrecked, and get the frame generally true, then let the frame shop do their stuff. Driving to the frame shop was a learning experience. Everything felt crooked, then from the frame shop, wow, like a new frame. If you start noticing that it seems to be going crooked again, have it retweaked after 6-12 months, depending on how bad it is messed up.
Just my $0.02
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Bent Wrangler YJ frame #627641 07/18/05 11:07 PM
tomriddle Offline
while it sucks that your rig is screwed, you should always aim for the middle like that. if you had hit with a front tire you would have driven your front driveshaft through your xfer case, cracked the trans and had to play at the frame shop as well. sucks about your ride, good luck with it.
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: Bent Wrangler YJ frame [Re: tomriddle] #627642 07/20/05 03:58 PM
Flouris Offline
Where in upstate NY are you located...I am originally from Rochester...
'95 Wrangler, 4.0L, Rock-it Air Intake, tornado, Performance Distributors Ignition kit, 31's, 2.5" Pro Comp Suspension lift, Hella fogs, Light Bar
Re: Bent Wrangler YJ frame [Re: Flouris] #627643 07/20/05 11:19 PM
tomriddle Offline
wayne county currently. i'm a 315er!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6087 MB (Peak: 0.6734 MB) Data Comp: Off Server Time: 2026-06-15 10:39:34 UTC
